Doulbe or single spring?
Go with single comp 918 springs .. the new vesion rated at 0.625" ..
Any way it deponds on the cam lobe .. ask someone like PG or Predator Z and they can give you the correct one
Personally I would stay away from the 918's because of their track record...new design or not. The Pac 1518's would be a better choice. A double will be a little more noisy and can rob a little power, but do offer some added benefits if one should break. What exactly are the specs of the camshaft you are going with?
