Pics of rollbar install
thought Id post some pictures of my rollbar install. It sure will be easy to detail the car at this point. I cut the window so i can do the walbro intank fuel pump upgrade.
got the carpet back down just have the seats and seat belts left. these pictures show the swingout drivers bar and the rear bar is removed. I included a picture of the underside plates. I used seam sealer (seam sealer is what GM uses where the body panels meet)to give the plates a flat surface and keep the water and dirt out. After i paint it (it is paintable) I think it will look very good.
VERY nice looking install. I'm getting close to installing a roll bar as well. Is that the wolfe bolt in that you are using? I've never seen a picture of the access hole cut for the fuel pump access, i think i will do that as well. Did you have to drop the tank to bolt the rear bars down? Again VERY nice install, i think i will save the pics if you don't mind for when i get ready to do mine.
Was gonna post some pics of the bar I just finished and saw this thread... Looks like my car did. I dont know if I want to do all that agian, good little job stripping everything out & putting it all back in.
Yours looks good. May go back and seal the under plates like that with some seam sealer, didnt think of it at the time.
I'm very happy with the Wolfe bar & the quality also. Got the chrome-moly bolt-in bar with the welded cross bar & then I TIG welded the two rear down bars to the main hoop, which from what I understand and have been told and the way I read the rulebook (which may not be right... lol) it is NHRA legal as long as those bars are welded to the main hoop... or should be legal... maybe... hopefully, but you never know with some of the Tech guys at some of the tracks.
bad2000ss and tallytransam: I welded the back bars down so I wouldnt have to drop the gas tank.
orange99Z: the bolt ins can be made to be legal.
sabastionlopezjr: your right about welding the back bars to the main hoop. Also my bar is not actualy NHRA legal because I got the removable rear bar. Im going to put some padding on the bar and i will cover the areas that have the bolts and hope for the best.
Looks very clean, nice work!
Only question is why cut the window above the fuel tank rather than droping the tank? I would personally think that gas fumes would be filling the car constantly.
coach: thanks for the kind words
What did u use to paint the cage? Im gettin my cage welded in and I dont know what to paint it with. My cage is from Competition Engingeering and it was only like 250bucks, we will see how well it goes in.
Looks good. I had my rollbar built from scratch by a local fabricator and welder. Cost me about $750 with removel and replacement of interior. Welded in, unpainted.
I went custom because I have long legs, and didnt want to be squashed against the dash board.
Good install, good pics!
