LG G5 cam installed and dynoed have a few q's
car:2004 GTO 6 speed
Mods:
unported stock 243s, pac springs, comp 7.4 PR
G5 cam 224/230 on 112lsa
cheap ps lt headers, catless mids
home ported tb
stock airfilter, air box, crank pulley, catback minus some mufflers welded in
car made
387hp
387tq
pulls great till 6200-6300rpm
what do u guys suggest to push it over 400hp level?
ud pulley, catback, ls2 maf, cai?
Mods:
home ported tb
car made
387hp
387tq
Internet Mechanic
Decent numbers, that LS6 head makes a diff. I would agree the supporting mods should get you over the 400 "Hump". I would definitly NOT touch the MAF, works fine and like said will screw with driveability once on the road. OR at least tell the tuner you have it and they will tell you what they recommend.
I was surprised at the tq number I was thinking it would be in the 370ish range. If I do a ls2 maf I would definantly get it re-tuned by the tuner. I heard the 85m maf was good for a solid 10hp on a cammed car.
ls2 maf=10hp
ud pulley=7hp
cai=8hp
catback=10hp
all in all with a re-tune I should pick up another 30-35h if I was guessing right.
ls2 maf=10hp
ud pulley=7hp
cai=8hp
catback=10hp
LSX Mechanic
My thoughts:
-That's a good cam
-An LS2 MAF is not going to make any more power. The stock MAF is fine.
-You are giving up an easy 10-15rwhp with the stock airbox
-UDP is worth 6-7rwhp. It's not really a "dyno" mod, but does show gains on the dyno.
-A bigger catback with bigger mufflers will make more power. Our 3" custom system we put on GTO's makes 15-18rwhp over stock.
-Keep in mind GTO's dyno slightly less than an F-body.
Lots of room for improvement. With some tweaks I don't think 420rwhp will be out of the question.
-That's a good cam
My thoughts:
-That's a good cam
-That's a good cam
don't you think the 3inch exhaust will kill some low end tq?
thoughts on a fast intake manifold? 90mm version and sell the ls6 manifold or just not worth it for a street car?
As hard as it is to do right now, try to get a OTR cai. Keep and eye out on ls1gto.com for a used catback or get cut outs. Like most have said, I dont think a ls2 MAF is worth the small amount of HP because of the possible tuning issues.
Get one of these intakes and get rid of the Maf you will definatley get over 400
They come from here
http://www.vcmstore.com.au/epages/sh...cts/VI-LS1-OTR
They come from here
hmm from besides this thread right here... i have heard about the same thing... deff get a better intake forsure... slp or k&n personally and all i know is when i put the LT's and the 3" true dual exhaust on my car it felt like a huge jump... but my car was tuned for LT's and true dual exhaust... and it had shortys and 2.5" y piped. but airbox and exhaust will make you over the 400... at least it should
