Catback mounting points please?
Old 09-08-2010, 05:22 PM
01Blk*SS*'s Avatar
Default Catback mounting points please?
I just recieved my magnaflow catback for my 2001 camaro. When mocking up the over the axle I pipe, I cant find where it mounts, I think the exhaust shop who did my true duals threw away the I pipe mounting bracket, Can someone please post pics of where the I pipe mounts to. I appreciate it, thanks!
ps. If anyone has the mount for a 2001 camaro, I would like to buy it. If not, a part number would be awesome!
Old 09-08-2010, 06:26 PM
Arc00TA's Avatar
I pipe does not mount to anything. It connects to the Y pipe and there is no further bracket until it goes behind the axle, it mounts right above/behind the axle. You should see 2 coarse threaded bolt holes there if you are missing that bracket, but it is for suspending the muffler.
Old 09-08-2010, 08:15 PM
01Blk*SS*'s Avatar
I figured this out after I jacked my car up. I said I pipe because I thought it was considered the length of the single pipe over the axle.
01Blk*SS*'s Avatar
btw thanks!
Old 09-08-2010, 09:15 PM
Arc00TA's Avatar
Are you still missing a bracket? The pass one is hard to get.
Old 09-09-2010, 11:37 AM
01Blk*SS*'s Avatar
yes, my car is missing it
I ordered one from gmparts direct, it consists of two bolts, and L bracket , and the rubbing grommet mount. about $55
