records
11.8x, Tim Cowle carbed 11.4x and of course Jon Beam 10.9 Procharged, all with a rocker swap I'm sure, but stock long block otherwise.
Shon HAD the record, now Tom Cowle has it, for the stock longblock. Basically it is the "bolt-on" record. Headers, cai, and anything goes with the chassis. Stock intake, cam, heads, block, pistons, etc, etc.
bolt-on record is 11.481 @ 118.98
As far as taking a 10-bolt far, there are lots of guys in the 10's with theirs. Keep in mind that you can invest a lot of money into one with better axles, stronger posi's aftermarket gears, a girdle, etc, etc. They still won't be as strong as a 12-bolt or a Dana60 or whatever though. I wouldn't hesitate to run one into the mid 11's with an auto car. They seem to be ok at that level.
9-Second Club
When looking at those "records" you need to look at car weights. A 2600 lb car is going to be about second quicker than a 3600 lb car. Most 60' times I see here are really sad. A light car that will 60' on the low 1.30s will be a lot quicker that a high 1.40 (or even worse) 60' in a heavy car. Same power level. Anybody weigh these "record holders"? Take 1000 lbs out of a car and you look a lot smarter to the guys that don't know any better.
ok my bad maybe i should have been a lil more elaborate...looking for the fastest et's and mph for stock bottom end and heads.......untouched bottomend and untouched heads so cam and power adder are ok.
