Factory LT1 Rear End Question
Old 09-08-2010, 09:47 PM
Xer0ta's Avatar
Default Factory LT1 Rear End Question
Doing a complete tune up on the formula, need to know what weight gear oil goes in her rear.
75w-90
80w-90
75w-150
Just a few of the options I have at work. Also, switching from factory spec'd gears to aftermarket 3.73 ratio ring and pinion, does the weight stay the same? I was thinking it might go a notch thicker.
Thank you in advance.
Old 09-09-2010, 12:43 AM
jaycenk's Avatar
They came with 80w and what do you mean by thicker? and weight?
Old 09-09-2010, 12:47 AM
LT1
LT1's Avatar
use the 80w-90 and add the GM limited slip additive.
Old 09-09-2010, 03:55 AM
01ssreda4's Avatar
75/90 and additive if you have an Auburn with the yellow springs.
Old 09-09-2010, 07:12 AM
shbox's Avatar
Right from the owner's manual...
Limited-Slip Differential
To add lubricant when the level is low,
use Axle Lubricant (GM Part No.
105227 1 ) or SAE 80W-90 GL-5 gear
lubricant. To completely refill after
draining, add 4 ounces (1 18 ml) of
Limited-Slip Differential Additive
(GM Part No. 1052358). Then fill to the
bottom of the filler plug hole with Axle
Lubricant (GM Part No. 12345977) or
SAE 80W-90 GL-5 gear lubricant
Old 09-09-2010, 08:10 AM
01ssreda4's Avatar
75/90 is better
Old 09-09-2010, 10:31 AM
ace3166's Avatar
If you do have the Auburn diferential,DO NOT use synthetic gear oil.
Also, make sure the car is level when filling. If it is just jacked up in the back, it will accept more fluid.
Old 09-09-2010, 01:22 PM
Xer0ta's Avatar
Tyvm, i'll pop the cover of and check the spring color. Yellow spring = no synthetic right
Old 09-09-2010, 04:21 PM
shbox's Avatar
Originally Posted by 01ssreda4
75/90 is better
...and that would be because?
Old 09-09-2010, 05:05 PM
ace3166's Avatar
Correct the Auburn diff's have the yellow springs.
Quick Reply: Factory LT1 Rear End Question
