First time out in the new car
Took the T/A out to NSD last night and after letting her cool off for about half an hour, I made a few passes just to see what I could get out of her. Biggest problem was when I hit second gear, I got pretty loose and my 60' was ****, but ended up getting a couple 8.5x's in both right around 84mph so I'm pretty happy (should I not be? haha)
Here's a crappy iPhone4 vid of me racing a Formy
[youtube]sNAh0YkYS6E[/youtube]
Stall? I see you have a tranny cooler but I don't see anything about a stall. If you get you some sticky tires and get your 60' down you would be looking good. But, not bad either way. Those times sound about right.
Yeah - up in Frisco; going to try and take it out ot Ennis later this year or early next year while it's colder and hopefully pick up (or borrow) a pair of DR's before then to hook better.
You are probably looking at about a 13.6 or so out in Ennis if you run it the way it is. That's just my guess of course.
Using the 1.55*8th calculation that I've heard is pretty accurate, it's saying 13.2x's is a close guestimate - using the DA correction, it'd be 12.97 @ 107mph - no clue how accurate that is, but if I can't break into the 12's with DR's I'll be pretty dissapointed.
