UMI Performance
09-10-2010, 10:58 AM
UMI Performance Inc.
Heavy Duty Billet Aluminum Sway Bar Mounts
Starting at: 89.99/set
These heavy duty sway bar mounts from UMI are CNC machined from beautiful T6-6061 billet aluminum and are nicely sanded with a clear finish to prevent corrosion. Large sway bars place a lot of stress on their mounting points and mounting brackets causing them to flex, bend or even break. These heavy duty aluminum mounts are a new replacement for the stamped steel mounts supplied with most aftermarket sway bars. The UMI brackets are supplied with new greaseable polyurethane bushings and grease fittings. Not only do these brackets reduce flex they offer a great touch to the underneath of your vehicle. Price is per set, one set needed for one sway bar.
Sizes available- 7/8" (22mm), 1" (25mm), 1-1/4" (32mm), 1-3/8" (35mm)
http://www.umiperformance.com/catalog/images/large/0048a_LRG.jpg
