how to install rear main seal with the engine on the stand
Old 09-11-2010, 07:40 PM
speedracer2536's Avatar
Default how to install rear main seal with the engine on the stand
any ideas? i dont have a engine hoist.. it looks like thats the only way.. any other ideas? just to be clear im doing a rebuild and its the whole adapter and seal
Old 09-11-2010, 07:59 PM
Village Troll
SS RRR's Avatar
You can wait until the engine is in the car?
Old 09-11-2010, 08:02 PM
can the oil pan go on without it? i thought the oil pan went of the two bolts at the back..
Old 09-11-2010, 08:08 PM
9-Second Club
Ed Wright's Avatar
Spacers & longer bolts when you hang it on the stand.
Old 09-11-2010, 08:11 PM
SpeedDensityZ's Avatar
That's the only other way I could have seen it done. Too late for that though. You NEED an engine hoist.
Old 09-11-2010, 08:13 PM
guess im headed to harbor freight.. lol
Old 09-11-2010, 10:27 PM
shbox's Avatar
The oil pan seals to the adapter, so it has to be installed before the pan.
Old 09-12-2010, 07:55 AM
Village Troll
SS RRR's Avatar
... to clarify if needed, just the adapter plate for the seal has to go on before the pan. Not the actual seal.
Old 09-12-2010, 08:44 AM
shbox's Avatar
That's what I said...the adapter. Should have been clear.
Old 09-12-2010, 11:23 AM
Village Troll
SS RRR's Avatar
I thought the "it" in your sentence was an understood reference to mean the seal. A thousand pardons...
Old 09-13-2010, 12:24 PM
duh
duh's Avatar
Just as an option....but you need 3 people....2 hold it while the 3rd loosens the bolts then lower the block so you can get to the adapter without too much struggle and tighten the bolts (u can also flip the motor and raise it with manpower)...it'll still be tight but it canbe done...definitely go buy a picker though, harbor frieght is cheap enough...
Old 09-13-2010, 12:48 PM
WhiteHot's Avatar
Harbor Freight is cheap but you get what you pay for. I got my hoist there and if I would lift the engine 3" off the floor, within 10 minutes it was sitting on the oil pan. They work for the occasional engine pull/install.
Old 09-13-2010, 02:32 PM
AChotrod's Avatar
I did it on the stand using washers as spacers with longer bolts.
Old 09-13-2010, 08:51 PM
Speedy's Avatar
This is how I did it:
Old 09-13-2010, 11:00 PM
airfix's Avatar
I was just about to post the same thing! Spin the engine upside down and you should have plenty of room, Just like shown in the pic above.
Old 09-14-2010, 01:01 AM
ill give that a shot.. seems like it can be done with one person if i just loosen the bottom two adjusters and ever so slightly the top too.. let it slide down..
Old 09-14-2010, 06:52 AM
Village Troll
SS RRR's Avatar
Why not wait until the engine is in the bay or just prior to putting the flywheel/flexplate on?
Old 09-14-2010, 10:54 AM
cause the oil pan needs to go on so i can prime the motor..
Old 09-14-2010, 11:34 AM
Village Troll
SS RRR's Avatar
The adapter, yes. Not the actual seal.
Old 09-15-2010, 10:04 AM
well thats the problem im having.. i need to put on the adaptor
Quick Reply: how to install rear main seal with the engine on the stand
