th350, 700r4 or rebuild 4l60e myself?
Old 09-12-2010, 11:09 PM
hoursetraitor's Avatar
Default th350, 700r4 or rebuild 4l60e myself?
okay guys i need input here. my trans is done, as far as reverse goes so i can get a th350 for really cheap and i mean like $50 same with a 700r4 but i cant get a 94 4l60e for any less than $600 and a t56 for no less than 1200.
so has anyone installed a 700r4 or th350 in a 94 car?
i know i need a way to set up a TV cable and figure out lock up. so theres so many variable im not sure my easiest/best option
Old 09-12-2010, 11:40 PM
FLT
FLT's Avatar
I would put the correct 4l60e in there and be done with it. Remember that the others are going to require some fabricating in order to work.
Old 09-13-2010, 02:22 AM
it doesnt seem like the al60e is very reliable so im concerned spending $600 plus for a used that might not last very long. i agree its the easier way. i would rather rebuild mine my self or go one of the other routes. the turbo 350 is probably a bad idea. so i need to figure out what it takes to make the 700r4 work.
so if i get a 93 throttle body will the tv cable hook up to it like the 4l60 that came with them? and what would my options be for controlling lock up? no lock up convertor? im going to need a new convertor anyways since theres crap floating around in my tranny.
Old 09-13-2010, 12:17 PM
Jays_SSZ28's Avatar
What are the odds of a $50 700R4 working?
Old 09-14-2010, 05:58 AM
pretty good when you pull it from a wrecked car at pull a part. 700r4s are a dime a dozen 4l60e's are not, unless i can make a 4l60e from a van or truck work i cant get one at pull a part...any tranny is $50 but they never get v8 camaros
Old 09-14-2010, 11:21 AM
Jays_SSZ28's Avatar
The first 700 I ever built came from a junkyard, $125 and it didn't work so I rebuilt it.
Every one after that I just picked out of the core pile for $40 and did a rebuild before installing.
So how do you know the trans you get works? I know the yard I go to runs some vehicles and say it yard drives, Which means basically 1st works.
If you get a 700 with ??? amount of life left in it you're looking at a rebuild or another $50 700. You could fix your 4L60E for about the same as a 700.
Old 09-17-2010, 07:19 AM
i find a car that got wrecked bad. usaully if they were driving and wrecked it the tranny will be good. i never pull them from a straight car.
i was reading up and if i can find a 2wd 94, 95 or 96 from a van or truck i should be able to use it in my car.i just want to get the car going so its drivable. so from what ive read if i swap the internal wireharness a 95 will work and for a 96 same thing and switch tail shafts. i might find one in a truck or a van and i think the 4.3l one is supposed to fit?
heres where i found my info
http://www.camaroz28.com/forums/showthread.php?t=476780
i have to get this car going incase i have to store it someplace else as i cant park it where i live
Old 09-17-2010, 09:53 AM
where do you suggest to get the rebuild kits for the 4l60e? i want all the steels, everything. i found 2 places on ebay but i want the best deal. i dont want to do it but its going to be the best thing.
is ther a way to clean out the convertor or am i stuck having to buy one?
im pretty sure its just my low reverse clutches so what else might i need to replace that wont come in a master rebuild kit?
Old 09-17-2010, 11:05 AM
Jays_SSZ28's Avatar
If you're on a tight budget you could take it apart and see what it needs.
I've reused steels a lot, as long as they're not burned.
For parts check out the sponsors here, or call Dana at pro built, bulkpart.com, transmissionpartsusa.com.
The converter needs to be cut open and cleaned, I used to have this done by a local converter shop for $65 to $125. Can't really flush it because of the clutch, it needs to be checked for wear.
Old 09-17-2010, 12:04 PM
Gingervitis Addict
slow67's Avatar
IMO a 700R4 is no more reliable than a 60E (if anything, other way around, as the 60E is an upgraded cousin of the 700R4).
Old 09-17-2010, 07:29 PM
a late model 700r4 uses the same convertor? as the 4l60e?
cheapest rebuild kit ive found was $140 with shipping included.
i still havent ruled out the 4l60e thats in trucks and vans
Old 09-17-2010, 08:09 PM
Jays_SSZ28's Avatar
A V8 700R4 converter will work with a LT1 4L60E.
Truck and van 4L60E's aren't any different than ones in cars, just calibration in the valve body and sep plate.
Old 09-18-2010, 02:16 AM
yeah i thought so...looks like my buddy who owes me is going to order one of the ebay master rebuild kits. so ill probably pull the trans in the next few days as soon as i know its ordered.get it good and cleaned up because im probably going to have to rebuild it in my living room lol.my girlfriend isnt going to be happy but oh well.i can practice putting it together a few times so when i put the new stuff in it ill get it right the first time
i have rebuilt borg warner t5's so i think ill do fine.
what items do i need to look at most closely? sun shell i know. any stuff i should upgrade that wont come with the rebuild kit? im excited to do this because it valuable experience that helps with jobs. tech jobs are hard to get right now. i wanna be done with the tranny and be able to beat on the car without worrys. its a low miles lt1 (105k) and it will probably become my daily driver.
Old 09-18-2010, 02:18 AM
crap in my tranny on sensor
grape juice tranny fluid
Old 09-22-2010, 04:15 AM
i just scored a rebuilt 93 4l60/700r4 took it all apart everything is in great shape and it was easier than i thought. anyone know how to tell if it has the beast sunshell? i dont know if i need to press out the low reverse piston or not if im pretty sure my low/reverse clutches are just burned up, i have a feeling something else might be bad by judging the metal on my speedo pick up. im basing my rebuild off of this write up, alldata a 700r4 atsg video and a manual for the 4l60e
http://helpwrench.com/forums/showthr...ics-and-Tricks
so any advice opinions?
Old 09-22-2010, 10:31 AM
Jays_SSZ28's Avatar
Thats a sun gear, this is the sunshell from your link.
I'd guarantee it doesn't have a beast sunshell in it.
This is a beast sunshell.
This is a broken stock one, where the arrow points is broken in this pic, but normally it's a 90 degree angle, the beast sunshell has more material there and is not machined to 90 degrees there.
The metal on the speedo pick up could have come from a bearing or, a planetary bearing/thrust washer, a thrust washer in the trans. Careful inspection might find the source.
Old 09-22-2010, 03:09 PM
this is what mine looks like. theres another rebuilt trans im going to tear apart today or tomorrow for practice and parts at the junkyard. might as well start collecting parts and learn how to build these things
Old 09-22-2010, 03:20 PM
this band isnt re usable is it?
Old 09-22-2010, 03:47 PM
Jays_SSZ28's Avatar
The band really doesn't look too bad, pretty sure that red material is not stock.
It's really not worth keeping considering you can get a new one for $15 to maybe $40.
Borg Warner Hi-energy is good. The cheaper ones are relined and the better ones have thicker mounting lugs.
Thats sunshell is stock.
You could reuse both of those parts if you're not putting down a lot of power.
Old 09-22-2010, 04:52 PM
good to know,
well like i said the trans they came from was rebuilt. it had some transpro brand valve body plate.since its a good chance everything is fine i will basically just switch gutts with my trans.
Quick Reply: th350, 700r4 or rebuild 4l60e myself?
