Pontiac GTO 2004-2006 The Modern Goat
Cool air intake squeeze
Old 09-13-2010, 07:32 PM
olgoat's Avatar
Unhappy Cool air intake squeeze
OK I purchased a Vararam intake kit and it does not fit. The hood contacts the top of the air filter and shoves it onto the upper radiator hose...Any suggestions?
Old 09-13-2010, 07:43 PM
ColeGraham's Avatar
you should have gotten the CTS-V
Old 09-14-2010, 06:53 AM
jlink's Avatar
Guessing this is otr intake? What year is your goat?
Old 09-14-2010, 09:51 AM
05TurboCGM's Avatar
It's not made for 04s...if that's what you have.
Old 09-14-2010, 11:56 AM
jlink's Avatar
That's why I asked him
Old 09-14-2010, 12:55 PM
ColeGraham's Avatar
he has a 2006 GTO, Silver with Black interior.
and what he left out is...that in the directions, you have to cut out part of the radiator shroud. and in doing this, i think over triple the amount of cutting was required by the directions. and it still contacts the hood, putting pressure on to the radiator hose. which in turn has started to produce a thin spot in the hose.
big thing here is, what type on intakes are you guys running or would you recommend.
Old 09-14-2010, 02:51 PM
jlink's Avatar
Well that suks. Wish I had an otr. I'm runnin a k&n.
Old 09-15-2010, 02:23 PM
slogoat's Avatar
I installed the Vararam and it fits fine, your hood liner will touch the very top of the upper part of the filter and it has made a little bit of a cut into the liner. Make sure you cut far enough down on the radiator shroud. The first cut i made was not far enough down. In doing so i cut away some brackets that hold the smaller coolant lines against the shroud, but that was nothing that some zip ties couldn't fix. I wasn't impressed with the fit and finish of it, but I picked up a tenth over stock in the 1/8 mile. Havent had it on the quarter yet. And yes the da's were the same. So i guess it is working. You're only other option would be the Svede intake, which is probably better than the v-ram, but there is a six month or more waiting list.
Old 09-15-2010, 02:25 PM
slogoat's Avatar
I wish i could have but they're too damn expensive. lol
Old 09-15-2010, 08:47 PM
gconnoyer's Avatar
The Svede intake is going to be going into mass production fairly soon. Maybe offered in carbon fiber as well.
Here it is on my car.
Old 09-20-2010, 02:34 PM
ColeGraham's Avatar
^^^ that is one nice set up
Old 09-20-2010, 02:41 PM
ColeGraham's Avatar
this is true...my dad (olgoat) got his GTO for 12 Gs less then i paid for my V...
but i have 4 doors, and a more comfy interior...and the same power with almost the same weight
but the GTOs are very nice, and would have love to see them (and the Firebird) continue on with the Camaro.
Old 09-20-2010, 05:52 PM
RX666's Avatar
i contemplated this intake /\ .. I need room to run a nitrous plate though and this does not allow room for a MAF and nitrous plate though unfortunately.
and NO, i am not running my car speed density.
Old 09-20-2010, 10:13 PM
cryptnosis's Avatar
+1 to svede. I have heard nothing but GREAT things about it and supposibly its going into full production mid october.
Old 09-26-2010, 08:04 PM
svede1212's Avatar
My intake will work with a FAST manifold, FAST TB, nitrous plate and any MAF you want all at the same time.
Old 09-27-2010, 11:59 AM
danieloneil01's Avatar
And what's the turn around time? 6 months? 12 months?
And I gave my vararam away. IMO, Ugliest CAI on the market period.
Old 09-27-2010, 12:08 PM
3.8redbird's Avatar
car?
Old 09-27-2010, 01:10 PM
svede1212's Avatar
Maybe 2 months. We have to get caught up on the back orders and then it should be in stock altho the orders have been coming in pretty fast
Old 10-05-2010, 07:54 PM
olgoat's Avatar
Thumbs down OTR Potential Blow-Out
OK, prior to purchasing the Vararam I informed both the manufacturer and the online reseller of exactly what I had. The day I went to install it I realized that it was not going to fit a represented. Now 6 weeks later it looks like I have some wall-art. I would offer this OTR POS to anyone for free but there is a serious fit problem: the unit, installed per instructions, bears down on the upper radiator hose, which resulted in rubbing against a wire guide for the driver side fan. If you have one of these on your Goat check the hose at the guide. When the hose blows it's messy and of course potentially devastating to your engine. My is an 06 but the LS1 could have similar issues.
Old 10-05-2010, 08:49 PM
hivoltagedriver's Avatar
I ditched my VR for that reason. The fitment flat out sucked. Will be switching to a CF Svede as soon as they are available.
Quick Reply: Cool air intake squeeze
