TSP 408 LQ9 short block question
I find a deal on a 408 LQ9 TSP short block, it's build with a Callies crank, eagle rods and diamond pistons. The guy said this engine should put compression around 10.5:1 according to the specs sheet he received. But he say it has -3cc dish pistons..?? This should raise compression to around 11.5:1 with gm gasket and a 0 deck. I think a -10cc pistons is more the right volume. I've check on TSP website and -10cc are available but only with a short block assembly.. so that's sound right. I have a picture of the short block, the piston are dish and look like a "mickey mouse" shape. -3cc only have valve relief normaly.
Here's the picture
Tell me what you think. Thanks!
Here's the picture
I'm no genius, but that looks like a set of dished pistons! I can say that a TRUE flat-top piston (with the appropriate valve reliefs) USUALLY are about -3cc to -4cc. Looks like you have a 408 for a low compression/forced induction build. Still a good set-up either way...enjoy it!
not trying to jack but I have -10 pistons and milled to 61 with the .40 head gasket.. what would that put me around then? I was thinking I was around 11:1? I run pump gas and its my dd.
If it's a TSP engine call them and discuss it with one of the guys there. They could prob give u a positive id of exactly what piston u have based on ur photo as well. They're great peeps with great service - they will help u as best as they can.
