built 6spd question.
i have been around in the other sections of this site asking questions about rear ends. as im almost sure of what rear end im going to run, I would like to pick out a good transmission to match my combo.
First off, I own a 2000 ws6 with an automatic, stock everything. Im almost sure i will be fitting a built 9" either from Moser, or MWC within a few weeks. ill be running 3.89s or 4.10s.
Next spring I will be running an LSX 427 backed by a 6spd. This is going to be a street car that i will run a couple times at the track.
What would be a good built 6spd that would be just about bullit proof for 600whp or so. give or take 100hp.
http://www.tick-performance.com/tickshift/
http://www.morrismotorsports.net/services
both popular vendors here. they both have stage 2 builds that should hold what your looking to put down. prices are good, so is customer service.
I build one that is a step above the typical Viper build that most shops offer for $1380. Of course, you will need a core T56 to start with, or I could work on finding one for you. IT's not nearly as easy as it used to be to find a core.
http://www.texasdrivetrainperformance.com/t56.html
Do a search on this site for "TDP" and you will see
