oil pump o-ring install on pick up tube first or pump first?
Old 09-13-2010, 09:14 PM
TurboZ28408's Avatar
Default oil pump o-ring install on pick up tube first or pump first?
on the oil pump o-ring are you supposed to install it on the pick up tube first or the oil pump first and then slide it in ? i was reading GMhightechperformance.com and they installed it in the pump first. curious on peoples opinions.
Old 09-14-2010, 04:23 AM
vettenuts's Avatar
Tube, it is meant to slide into the pump where there is a chamfer to step down the diameter and squeeze the o-ring. That was dumb of the magazine to do it that way.
Old 09-14-2010, 05:38 AM
69LT1Bird's Avatar
Tube.
Old 09-14-2010, 09:18 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Definitely onto the tube first, and then the tube with o-ring into the pump!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-14-2010, 09:22 AM
tording99Z28's Avatar
What magazine did that, hopefully not GMHTP!
Old 09-15-2010, 02:04 PM
gmhtp in their budget stroker article i think
