has onyone tried a 15x12 wheel under an fbody?
I have 15x10 prostars and they stick out 1" with a 7" backspacing (maybe 6.5, been awhile). The Bogart's would probably fit and they would know the answer. With a little more backspacing then they would probably look like my Weld's. I run a 13.5 Hoosier QTP. Haven't been to the track yet but I'm sure they will rub the back bumper once the swell up and I will probably have to cut them some.
ERIC
ERIC
I ruin the end of films...
The tire you had on would also make a difference. I've seen people fit a 10.5W tire (and they're right at 11" wide), but it requires some hacking. I've got a 28" drag radial on 10" Bogart D-10s and I had to do some hammer work to the wheelwells and cut off the bump stop.
