Opinion of cam only on a 200K mile motor
I have a 2000 ls1 with 199k miles. This is not my only car, but I drive it at least 3 or 4 times a week rain or shine. I might go to the drag strip twice a year, I also just went on a mountain cruise and enjoyed that very much. Only thing I didn't like was seeing the coolant temperature rise slightly, but not enought to be concerned. I want to do a mild cam like a G5x1 228-232 or a 224-230. I will be using stock 243 heads with new springs and getting headers also. The car runs pretty solid and doesn't burn any oil or smoke. puts out 337whp and 334tq. Oil pressure hot idle is 22-28 psi. Current mods are:
LS6 Intake
powerbond udp
vararam
borla street catback 2.5''
LS7 clutch and flywheel
Question is, would you just run headers and get a tune or rebuild or find a new bottom end before installing different heads and cam? The lifters, pushrods, and oil pump will be replaced if doing the cam. The motor is the original and has never been apart. Thanks
LS6 Intake
powerbond udp
vararam
I wouldn't do it, was in your position a couple months ago. Did heads and cam on a high miliage motor and spun a bearing while tuning it. Installing a LQ9 now, which only cost me $200 more than my heads and cam setup. Good luck with whatever you decide.
i have had heads cam on my 200k+ motor for 2 years now. i am expecting it to blow up at some point but still running good. my motor was pretty well maintained its whole life it appears. but like stated it can/will blow up so if you do heads cam prepare for worst case scenario.
thanks for the replies, Ive heard more than once to get another bottom end or rebuild. Ill probably just do the headers and a street tune and then wait till she goes! At least if she does I will have all my bolt ons at that point.
yeh that's what i'm doing with my ls1, its done 195km's (121+miles i believe), i'm going to do mild cam, new oil pump and possible heads, when the bottom end goes, i'll put a stronger bottom end in then.
yeh the cam i've got works between 1800rpm and 6200rpm, iv heard from Holden mechanics in Australia about ls1's snapping cranks and spinning bearings when bassicaly brand new, so all depends, as long as your not revving it out to 7,000rpm every time (depending on cam specs) should be ok id say.
guess its a half and half decision. The radiator is fine and the only reason I said anything because I was running the car hard for about 30 minutes straight going uphill. It cruises around 198*F stock t-stat. Again thanks for the replies everyone.
It just depends on how good the engine was taken care of. Mileage really doesn't matter, im not sure why people ask this question. If I had a car that oil was changed with like amsoil every 3k miles, not beat on much and the car had 150k on. I would trust that more then a car with 20k miles that was beat on everyday and had normal oil changed twice in its lifetime. It's common sense really and your motor can be in great shape yet always a chance a bearing can go up in the rpms. I would say go for it if you knew it was taken care of and just keep in mind you may need money for a motor down the road. I'm almost at 108k, got my car at 70k, and did cam swap at 90k. I beat on it often but car is taken care of with maintenance it needs often and on time.
How many of the 199K have your put on the car? More so, how much of the PM have you done and has it been done on time. If the PM was done regularly, then id say that your chances of blowing up are about the same as a lower mileage engine. PM goes a long way for internal longevity.
1) Do a compression/leakdown test.
2) New Radiator/T-Stat
3) The G5x1 you can shift at 6,200 / 6,500 rev limit
4) Ported LS6 oil pump to get more oil in there.
5) LS2 Timing Chain
I think with doing all of this you will be fine. Now if you notice some problems with a compression test then I would hold off. Might not be a bad idea to put some LS7 lifters in there if you are going to be pulling the heads for added saftey.
5) LS2 Timing Chain
