T56 List
Old 09-15-2010, 06:20 AM
borrone821's Avatar
Default T56 List
About to pull a T56 out of a 99 Camaro SS. Exactly what do I need to take off the camaro to mate the T56 to an LY6?
Trans , bellhousing, Slave MC, Throwout bearing, clutch, what else? I'm assuming I'll need a new pilot bearing, is that correct?
What else might I need? Do I use the 6.0 flexplate or the LS1 in the camaro?
Just trying to figure out everything I need to get
Thanks guys
Jim
Old 09-16-2010, 09:16 PM
borrone821's Avatar
Anyone? Just need to know if an T56 out of an LS1 camaro will fit on an LY6 and what's needed to get that to happen
thanks
Jim
Old 09-17-2010, 01:43 PM
LS123's Avatar
What is a LY6? If people know what type of engine it is, they might chime in.
Old 09-17-2010, 02:08 PM
jmd
jmd's Avatar
What year 6.0? If it's after 2000, the crank is functionally the same as the Camaro crank with regard to balance, length, pilot.
The early ones used spacers or something...
The truck starter is probably the same location as the Camaro starter so the bellhousing will work but grab the starter just in case.
The flexplate won't help you any.
What's it going into?
Old 10-20-2012, 09:05 PM
Powe's Avatar
Bump on this question?
Quick Reply: T56 List
