res delete pipe question
I just went to my local exhaust shop and had them chop it off and re-weld the same size pipe as my cat-back system. It only cost like $25 and 20 min of my time.
I am going to by the pipe and have a friend weld it in for me. Does anyone know how long of a pipe I should get I was thinking like a 3 foot pipe to start off with would be more then enough.
Yes, most people prefer the sound of my car over the sound of a stock GTO... Though I think they are nuts.
It is slightly raspy, and definitely much deeper. Not a whole lot louder but definitely sounds better than with it.
The Magnaflow Exhaust certainly sounds better but you cannot go wrong for 40 bucks.
Mine sounds much deeper and is only raspy when I stab the throttle in neutral or park when the RPM's fall to idle. I can tell you that it is much more pronounced in the cabin of the car though. It rattles my console sometimes when driving. Kinda annoying, but nothing a little HUSH mat cant cure.
Sounds quite a bit different when the car is revved, but even with my subwoofer turned all the way on, I'm not hearing a huge difference. Sounds about as loud, just a little more raspy.
