flowmaster merge 3 -3 1/2 vs flowmaster merge 3-4 inch
Old 09-15-2010, 04:55 PM
droptopT/A's Avatar
Default flowmaster merge 3 -3 1/2 vs flowmaster merge 3-4 inch
ok heres the deal guys i already bought the f/m merge the 3 1/2 to a cut out 3 1/2 but im kinda regreting purchasing the 3-3 1/2 merge should i sell it and buy the 4 inch merge and 4 inch cut out
Old 09-15-2010, 04:56 PM
droptopT/A's Avatar
my mods are heads,cam,intake,lts,boltons
Old 09-15-2010, 05:29 PM
Engine_HP's Avatar
no biggy since u have a cut out.
Old 09-15-2010, 11:00 PM
droptopT/A's Avatar
bump to the top
Old 09-15-2010, 11:40 PM
TORCHD 02 TA's Avatar
I have the same merge, have a 228/232 cam and make 419/382
See my mods in my sig
Old 09-16-2010, 12:20 AM
droptopT/A's Avatar
i have a siimiliar cam lg g5x1 228/232 with patriot stage 2 heads hopefully i dyno about the same i dont think the 3 1/2 would hurt performance that much i mean how much hp could i gain with 4 merge vs the 3 1/2
Old 09-16-2010, 01:36 AM
BlkBird2000's Avatar
I just bought a 3-3 1/2 flowmaster merge and cutout. 3.5"s is a lot of pipe. I don't you will gain anything going to a 4" cutout. You'll just have less ground clearance.
Old 09-16-2010, 01:53 AM
hitmanws6's Avatar
you are fine, its not worth the effort to buy a new one and switch it out
Old 09-16-2010, 04:31 AM
You won't gain much going with an extra .5"... you'll make up the difference using your cut out
Old 09-16-2010, 10:55 AM
droptopT/A's Avatar
with this set is there still the need to change out the cat back cause im running a stock catback with a flowmaster muffler welded in place of the stock iim no fan of the flowmaster but it came with the cat back lol.
Old 09-16-2010, 03:12 PM
hitmanws6's Avatar
Yes rip that **** out, the flowmaster is holding you back a lot
Old 09-16-2010, 03:24 PM
omarrakeen's Avatar
there will be no difference and even if theres it wont worth the effort specially you are having a cut out, that will cancel it out.
Old 09-16-2010, 05:48 PM
Like Hitman said.. The chokemaster is holding you back prolly ~10 RWHP.. Get rid of that junk
Old 09-16-2010, 09:11 PM
01SS99red's Avatar
If you want to run open y-pipe I would get the 3-4 in. merge and run a turndown, but if your running a catback just run what you got.
Old 09-16-2010, 11:09 PM
droptopT/A's Avatar
only wiith the cut out closed right with the cut out open i see no need to spend an extra couple of hundred on a cat back or would it help even if the cut out is open
sorry for all the questions but im kinda broke and trying to avoid spending too much money
Old 09-17-2010, 11:43 AM
chrs1313's Avatar
I have a stock catback too with a 3.5" cutout...i made no more power when pulling the catback on the dyno back to back, so it is doing it's job...
I do have the 3-4" flowmaster merge...then reduced back down to connect to the catback...I run open y pipe at the track with a v band connection...
Jonas you see the new numbers ...check out the dyno section
Old 09-17-2010, 03:53 PM
No Chris I haven't.. I will look at them now
when the track outing? I am this weekend and the weekend of the October 2nd
BRB......
Old 09-17-2010, 04:43 PM
chrs1313's Avatar
going on Sunday to Byron...should be about to run around 10.3-4 air depending...
Quick Reply: flowmaster merge 3 -3 1/2 vs flowmaster merge 3-4 inch
