Resetting oil change light?
Old 09-15-2010, 09:21 PM
dbs1's Avatar
Default Resetting oil change light?
Can someone remind how this works on the 02 ss camaro, and the oil capacity? Thx!
Old 09-15-2010, 10:50 PM
LS1Tech Sponsor
06MonteSS's Avatar
should be right in the owner's manual for both...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 09-15-2010, 10:58 PM
CoreyD's Avatar
Correct me if im wrong, but to reset the oil change light you need to put the car in accessory and floor the gas pedal 3 times, and thats it.
Old 09-15-2010, 10:59 PM
Jays_SSZ28's Avatar
To reset the light turn the key to run (engine off) and either hold the odometer reset until the oil light flashes. Or press the gas pedal to the floor 6 to 8 times or until the oil light flashes.
Oil capacity is 5 1/2 quarts with the standard filter or 6 quarts with the longer truck filter.
Old 09-17-2010, 11:17 AM
tennerv8's Avatar
My '99 sierra owners manual says to put the key forward without starting it and push the gas pedal to the floor three times.
Old 09-17-2010, 12:15 PM
Z Fury's Avatar
I just reset mine this week. Turn the key to the Accessory position. Hold down the Trip reset button on the odometer until the oil light turns off. That's it. It took me over 10 seconds for my light to turn off, so don't expect it to turn off too quickly.
I've never heard of the gas pedal reset that the others are talking about.
Old 09-17-2010, 12:26 PM
Johawk's Avatar
The gas pedal reset will work in any car from GM with an oil change light or computer with oil life expressed as a percentage. The other methods differ between models.
Old 09-17-2010, 01:12 PM
dbs1's Avatar
The trip reset did it. I know in my 07 truck the 3 pushes on the accelerator does it with it. thx!
Old 09-17-2010, 01:17 PM
BIG_MIKE2005's Avatar
^Yep, I always just use the trip reset.
