Best way to pull off heads without coolant everywhere
Whats the best way to pull heads without dumping coolant all over the place? Would I be able to pull the coolant sensor on the driver side and the plug on the pass side and get most of the coolant out?
I read a trick on here and it worked for me. Once the water pump is removed, take a strong shop vac and suck out the remaining fluid via the passages on the front of the motor. I did this, pulled the heads and had hardly any fluid left over that went into the head bolt holes.
^^^that is the right way to do it and fully agree with the last 2 posts. But in the past i have used the shop vac to get as much out as possible through the waterpump inlets, then duct taped a straw to the shopvac to get as much out as possible with a little redneck engineering. It worked for me that way to but it isn't the right way to do it though. The good thing about using the coolant plugs is that you will be getting out all the old coolant too which isn't a bad thing.
