when is a rich idle with a cam too rich?
Old 09-16-2010, 12:08 AM
printmanjackson's Avatar
Default when is a rich idle with a cam too rich?
I understand you can not run stoich at idle when you have a cam with overlap and it needs to be rich but how much is too much? Do you just let the 02's take care of it?
Old 09-16-2010, 01:06 AM
5.7 ute's Avatar
The short circuiting you get from a cams increased overlap will have your wideband reading lean, not rich at idle. I found with my cam around 15.2 on the wideband gives me the best idle quality. You will need to experiment to find what yours likes.
Old 09-16-2010, 06:34 AM
I thought overlap from a cam caused the o2's to see more air from the intake which makes it look lean therefore it added fuel. maybe I got it backwards
Old 09-16-2010, 09:25 AM
Restricted User
98Z28CobraKiller's Avatar
Low 13's is OK. 12's is too rich.
Old 09-16-2010, 03:10 PM
BLK02WS6's Avatar
Most of them will be happiest at 14.5 to 15:1...
Old 09-16-2010, 04:32 PM
I just checked my CL idle and it's between .96-.97 Lambda and the fuel here is e10 93 oct. (all the pumps say up to 10%)
If I turn the o2's off it idles right at Lambda 1.00 (LTFTare always off)
it might be my conversion of AFR to Lambda that is making it look like this.
does this sound about right? I have ran it some with an OL idle but I got some misfires.
Quick Reply: when is a rich idle with a cam too rich?
