anyone running a 228/232 112 LSA cam please come in
Old 09-16-2010, 10:09 AM
Rise of the Phoenix's Avatar
Default anyone running a 228/232 112 LSA cam please come in
Will likely be using this size cam with my AFR heads milled to 62cc. Looking for anyone running this cam to comment on it and possibly post a video.
Old 09-16-2010, 10:20 AM
kdavis's Avatar
I just put a trick flow cam in my car, but I haven't started it yet. Should be able to post a vid, dyno numbers, and track numbers here in the next few weeks.
Old 09-16-2010, 10:56 AM
incbed's Avatar
I have 228/232 588/595 XER lobes 112 LSA even....I have mildly ported 243 heads with 2.055 intake valves.
It is in the process of getting fully tuned today ,,,but on just a flash tune the car was easy to drive even in traffic,,,,also it pulled extremly hard from 3000rpm and up. The engine was idling at 950rpm and you can hear the cam lope pretty good ,but it didn't have as much lope as the TSP V2 with 112 LSA,,but I think thats because it wasn't fully tuned yet.
I will be getting my car back this afternoon
The following users liked this post:
mikeak. (12-01-2019)
Old 09-16-2010, 11:11 AM
01ssreda4's Avatar
Who's cam are you refering to?
I'm about to install a cam motion 228/232 .612/.612 113+4 soon. I will post results when I have them.
Old 09-16-2010, 12:06 PM
You think the tune will make it lope more? Also, doesn't adjusting the idle make it lope more? I would love to run a bit bigger cam, something like the Torquer V.3, but I don't want to flycut, so a 228/232 112 LSA is really my biggest option. I like the fact that the cam pulls hard in the lower RPM's, but I want the cam to sound good too. I really like the way the Torquer V.3 sounds and performs. Deffinately post up a video when you can.
Old 09-16-2010, 12:07 PM
Not refering to any brand. I want the lobes to be the XE-R, so who would you recommend?
Old 09-16-2010, 12:41 PM
incbed's Avatar
I spoke to my tuner this morning and he said that my computer was still using the factory timing so my guess is thats why it didn't have alot of lope to it.
It should have alot more lope after he finishes fully tuning my car this afternoon. It should also pull earlier in the RPM range to once fully tuned.
Also I orderd my cam from TSP threw there custom cam option.
Old 09-29-2010, 04:57 PM
bkel33's Avatar
My '99 Vette is running a 232/232 112 w/ trick flow heads. Sounds great and still maintains awesome drivability.
Old 09-30-2010, 12:26 AM
SOMbitch's Avatar
Well those are Comp lobes so basically anyone can get them but I would recommend going through a sponsor on here..
Yeah I run the "as cast 220's" and can't say enough good things about them... Brian worked them a bit too so that helps me...
Old 09-30-2010, 04:45 AM
masterz28's Avatar
Did a good amount of research finally desided on somewhere on a 228-234 variety cam. Want to use the same lobes on both, xer look good. Have P&P 243 heads and P&P TB with ls6 intake should run very well good info here.
Old 10-01-2010, 05:50 AM
stryder's Avatar
i have a 228 232 on a 114+4 LSA the lift is .588 on the intake and .595 on the exhaust its not to lopey it is choppy. I have it on xe-r lobes but i would try the newer lsl lobes they seem to be doing good.
Old 10-01-2010, 06:58 AM
printmanjackson's Avatar
look at the new EPS lobe cams
Old 10-01-2010, 04:50 PM
Viper's Avatar
I'm running this a similar cam, 227/231 575/578 111 custom FTI cam with AFR heads milled to 62cc.
Here is the video:
http://www.youtube.com/watch?v=QL42Ya59vgQ
And yes, I can't launch or drag race real well but I wanted you to hear the sound.
Old 10-01-2010, 05:24 PM
MASS seller approved
low2001gmc's Avatar
who's cam are you refering to?
I'm about to install a cam motion 228/232 .612/.612 113+4 soon. I will post results when i have them.
let us know if you had to notch the pistons?????
Old 10-01-2010, 10:39 PM
mvvette97's Avatar
I have a 228/230 on a 112. I think it has plenty of lope.. Here is a vid of it, don't mind the startup surge because I got that tuned out of it..
Old 10-02-2010, 12:11 AM
01ssreda4's Avatar
Why in the world would you think I would need to flycut with this baby cam? I am going to measure ptv though.
Old 10-02-2010, 12:26 AM
*02WS6TURK*'s Avatar
Look into the EPS. I just got my EPS 226/230 .598/.600 114+4 cam...should have results here soon.
Old 10-02-2010, 07:47 AM
DCC!!'s Avatar
does it still have that much lope after you got it tuned or did it calm down a little?
Old 10-02-2010, 09:03 AM
mvvette97's Avatar
It was tuned then but he didn't have the starup correct. I got that figured out myself. It sounds the same but without the idle hunt
Quick Reply: anyone running a 228/232 112 LSA cam please come in
