VSS wires ?
Old 09-16-2010, 10:43 AM
crazystangg306's Avatar
Default VSS wires ?
OK i have a tremec t56 magnum that i am using in my swap. on the vss sensor it has a + & - for the plug on the trans. its a ford vss sensor. my harness has the fbody t56 plug A low signal & B high signal . my question is do i put b high signal to the positive and a low signal to the negative ?
Old 09-16-2010, 10:51 AM
Just got off the phone with D&D He said it don't matter
Thanks anyways
Quick Reply: VSS wires ?
