Engine pinging?
Engine pinging?
Hello,
i hear a very noticable sound from the engine which, i think is pinging. i can hear it very good in 2nd gear, ~1000rpm-3000rpm with 1/4 - 1/2 throttle. today it threw an error code, but it did go away after about 20 minutes.
i ordered an obd2 scanner because my stupid opel dealer in germany could not read the code..... fuel filter is on the way and tomorrow i'm gonna clan the maf.
is it really possible that a basically stock ls1 pings that bad and does not retard the timing?
thanks,
patrick
thanks,
patrick
i read the error codes and there are four of them
P0171 - System Too Lean (Bank 1)
P0174 - System Too Lean (Bank 2)
P0327 - Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor)
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
any ideas?
the short hose from the pcv valve to the manifold is rotted. hopefully a new one cures the problem!
any ideas?
today i noticed what i believe is a lean backfire through the manifold. happens above 4k rpm with wot. otherwise it drives fine.
trouble codes are P0327 and P0420. but no "system too lean" this time...
