5.3 into a toyota
Old 09-16-2010, 08:53 PM
mxracer12's Avatar
Default 5.3 into a toyota
hello everyone, im new on here but have been building cars since i was 15, im new to the ls style motors but have basic ideas on how they work, my question is i have a 5.3 out of an 07 silverado 4x4 and im swaping it into a 85 toyota pick up, the toyota already has a 350sb chevy in it that i swaped in when i was 16, i am wondering where i can get the harness for the motor since the motor i got was taken out and someone else bought the factory harness, im gona run a th350 trans so all i need is a motor harness and im gona run a cable throttle body of a older 5.3, i also need a pcm , any help would be great
Old 09-16-2010, 08:55 PM
In-Zane Moderator
ZONES89RS's Avatar
Or you can go carbed for cheap and make more power without getting the high dollar EFI intake.
Old 09-16-2010, 08:59 PM
chevyboy91188's Avatar
that might have a 54x reluctor being from 07 i dont know if you can use a cable tb it thats the case, because all the ecm's for the 58x would have had dbw, so you would have to convert the harness over. the carb may be your best option, but again do they have one for the 58x
rotor vs. piston's Avatar
ebay and the for sale section here. Speartech has some ready made ones too.
I have a GTO LS1 in my 89 2wd yota... STILLLLLLLLL, need to get the thing registered and on the road.
Old 09-16-2010, 09:27 PM
mxracer12's Avatar
that motor swap looks badass, so what would be involved in converting the harness to cable throttle body, i know that i need a spedo converter so there is an electronic vss but i can get that from dakota digital, and i also know that i need the spacer for the torque converter, does anyone know the gm part number for that spacer?
Old 09-16-2010, 09:29 PM
first before you worry about converting the harness look at the crank position sensor and see if its grey or black, if its black its 24x and you are good to go just get a harness for a 99-02 truck
Old 09-16-2010, 09:31 PM
mxracer12's Avatar
sounds good, the motor gets to my shop on monday
Old 09-16-2010, 09:32 PM
mxracer12's Avatar
i plan on keeping the truck intake and everything, it is a complete motor except the harness
Old 09-16-2010, 09:35 PM
do you know if it was out of an 07 classic or 07 new style? that would help clue in as to what the cps would be most likely
Old 09-16-2010, 09:36 PM
mxracer12's Avatar
it is an 07 classic
Old 09-16-2010, 10:03 PM
oh good the classic "should" have the 24 but you will know for sure when it gets there
Old 09-18-2010, 09:37 AM
tonytone4143's Avatar
lol,my brother is in the progress right now in his 78 corolla 1.8..i love it stuff
Old 09-18-2010, 06:24 PM
90LS1TOY's Avatar
Should not have a problem. I have a 90 extracab with ls3/t56 with p/s and a/c. These trucks have about the same underhood room.
Old 09-18-2010, 09:48 PM
awesome looking swap bro
Old 09-19-2010, 12:56 PM
BlueMagicSS's Avatar
Nice Swap!!!
Old 09-21-2010, 01:44 PM
mxracer12's Avatar
i got the motor 2day and it looks like the connector is black, is it a 2 wire connector or a 3 wire cuz if its 2 then its black and if its 3 then its tan,. i think its the black one tho
Old 09-21-2010, 06:03 PM
90LS1TOY's Avatar
Default 5.3 l
You will have to modify the hood for that.
Old 09-21-2010, 06:55 PM
its the one right by the starter and its 2 wire so you are good to go get a harness form a 99-02 truck or one from a camaro and get it going lol
Old 09-22-2010, 12:54 AM
mxracer12's Avatar
i got the motor up on the stand 2day and started to pull it apart to replace the 2 bad lifters and change the cam, im still undecided on what cam, i want some street manners but the truck will run in the mud sometimes, y would i have to modify the hood, my small block fit with about 2 inches between the hood and air cleaner, i have 8" suspension lift plus 3 body so i should have tons of clearance
Old 09-22-2010, 07:33 AM
90LS1TOY's Avatar
Default hood
Did not know you had a 3 inch body lift.
Quick Reply: 5.3 into a toyota
