Any 11-1 1/8 -26 Disk in lt1
Old 09-16-2010, 09:01 PM
BBC79Z's Avatar
Default Any 11-1 1/8 -26 Disk in lt1
Just trying to find out if i can use any 11 1 1/8 -26 clutch disk in my lt1 formula? It has a center force pp. Thanks for any info.
Old 09-16-2010, 11:00 PM
jmd
jmd's Avatar
With a standard disc, the sprung hub is located towards the rear facing side of the disc. The springs in the hub are compressed when the clutch engages and spins the friction ring of the disc clockwise (from the front.)
The Valeo pull style setup for the LT1 cars has the hub located at the front facing side of the disc. So the hub is sprung backwards, so you need an LT1 T56 specific disc unless you're going solid hub from a ZF S6-40 Vette.
Old 09-17-2010, 04:11 PM
BBC79Z's Avatar
Thanks for the heads up.
