Need a Couple Ind. T56 Parts
Old 09-17-2010, 12:53 AM
Wnts2Go10O's Avatar
Default Need a Couple Ind. T56 Parts
ive looked around but all the places ive found only sell packages of bearings and snap rings.
Old 09-17-2010, 07:19 AM
85MikeTPI's Avatar
What parts in particular? Most of the bearings are available individually as Timken sets. (more expensive, but not as much as a complete bearing kit) Some of the larger snap-rings can be safely reused, but the smaller ones are more likely to need replaced after every removal. (A complete snap-ring kit is only $20-$30 IIRC)
Old 09-17-2010, 07:32 AM
Josh18Fan's Avatar
http://www.tick-performance.com/tick...body/t56parts/ ?
Old 09-17-2010, 09:26 AM
RedRallyeZ's Avatar
^^yup. Tick has a whole page filled with parts.
Old 09-17-2010, 04:39 PM
Wnts2Go10O's Avatar
the thing is i dont need the entire bearing kit i need the bearings that ride in the races on the ends and the races themselves.
ill check out the timken thing.
Old 09-17-2010, 07:56 PM
Wnts2Go10O's Avatar
mike, would happen to know of an online store that has that stuff?
Old 09-19-2010, 02:34 AM
TDP
TDP's Avatar
Are you talking about the small bearing on the end of the mainshaft, that rides in the input shaft? It's also the same bearing at the end of the countershaft extension. If this is the one you are talking about, the it's Timken part number is LM12749, and the race is LM12711
If its another bearing that you need, just let me know and I can help you out.
Old 09-19-2010, 08:37 AM
85MikeTPI's Avatar
You can grab a Timken catalog and see what applications the T56 bearings are used in, then find them as sets at many online or local autoparts stores.. The autogear catalog lists the Timken numbers for most of the T56 bearings.
http://www.autogear.net/pdf/T56Catal...ro_93_2002.pdf
I almost always replace the small mainshaft bearing/race, which is the same as the extension shaft bearing and race. I found they are sold in most Autozones,etc. as SET16.
http://pdf.directindustry.com/pdf/ti...7228-_677.html
Sometimes you can't find the exact "SET" and have to buy a SET just to get the bearing you need, but not the race.. It's a little effort and much easier to get a full bearing set, but needing just 1 or 2 from the full set can make it more cost effective... YMMV..
Quick Reply: Need a Couple Ind. T56 Parts
