New Products Showcase - BMR Launches New Product - 67-69 F-Body Weld-on Subframe Connectors (SFC006)
BMR Suspension
09-17-2010, 08:25 AM
BMR Fabrication
Weld-on Sub Frame Connectors for the 1st Generation F-Body
Stiffen up the chassis for greatly improved handling in your 1st Gen F-body with Weld-on Sub Frame Connectors from BMR Fabrication. This product is constructed from 2” x 2” x 0.120” laser-profiled square tubing and 3/16” CNC laser cut steel mounting plates. The BMR Sub Frame Connectors (SFC006) weld through the floor pan, connecting the front sub frame to the rear sub frame. The unique profile provides OE ground clearance and an unparalleled structural advantage compared to other designs. Provided with Delrin body mount bushings and grade 8 mounting hardware. Installation time is only 3-4 hours.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrfabrication.com (http://www.bmrfabrication.com/), email sales@bmrfabrication.com, or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
http://www.bmrfabrication.com/ForumImages/SFC006_forum.jpg
