Got a b&m #70264 dope style with high stall? Comeon in...
Old 09-17-2010, 04:40 PM
senicalj4579's Avatar
Default Got a b&m #70264 dope style with high stall? Comeon in...
Whats your temps with this setup? Im trying to get the best possible option for a trans cooler setup. I have a ssra so by the radiator is out of the question. Im even considering running 2 of those B&MS if 1 is not enough. What temps are you guys seeing?
Old 09-18-2010, 12:44 PM
Z06 Steve's Avatar
dope style is easiest install only draw back is rad fan cant pull air thru it. do a search theres one method where a cooler is mounted with the ram air in place
Quick Reply: Got a b&m #70264 dope style with high stall? Comeon in...
