no spark help please
Old 09-18-2010, 03:56 PM
dwnshft82's Avatar
Default no spark help please
car wont fire i have checked the fuel pressure it is good i stuck a old spark plug in the front 2 spark plug wires and no spark i assume there is none in all 8 cylenders not sure where to go next any ideas
Old 09-19-2010, 07:01 PM
crainholio's Avatar
Disconnect, inspect for bent/damaged pins, and re-connect both your cam position sensor and crank positions sensor.
Old 09-19-2010, 07:07 PM
dnkynrbk's Avatar
Probally a crank sensor or cam sensor. I had a bad crank sensor one time and it would fire.
Old 09-19-2010, 07:25 PM
crainholio's Avatar
And if not the sensor(s), next step is the two grounds located at the back of the driver side cylinder head. Clean and tightly connected.
Old 09-20-2010, 03:25 PM
dwnshft82's Avatar
first thing i did was clean all gronds i will check both crank and cam sensor and replace the crank if cleaning dos not work thanks 4 the help
