is a 96 3.8 Camaro PCM OBD2?
Old 09-18-2010, 09:43 PM
1995blacktattop's Avatar
Default is a 96 3.8 Camaro PCM OBD2?
A friend of mine is looking at a 96 camaro with a bad PCM that will only run for a short time then die.
Does anyone know what the PCM part no would be? is it OBD 2? and does anyone have one for sale?
thanks.
Old 09-19-2010, 12:54 AM
horist's Avatar
96 would not be OBD2
Old 09-19-2010, 09:26 AM
lol so you're saying it's not and i got a PM saying all 1996+ cars are OBD2 which is what i orginally though until i read somewhere that the 3800 camaro was obd1 part way through 96. I'm trying to figure out which kind of PCM to have my friend buy without actually seeing the car first since its ~ 200 mi away.
Old 09-19-2010, 10:19 AM
BaddBird's Avatar
Get the build date from the car to make sure. 96 is OBD2 they made the change over to OBD2 in 95.
Old 09-19-2010, 01:43 PM
skalor's Avatar
It's OBDII, you might want to put in a '97 PCM though because HP Tuners doesn't support '96.
Old 09-19-2010, 06:58 PM
what year PCM's will work with that car? 96-02?
Old 09-19-2010, 07:07 PM
skalor's Avatar
Only '96 or '97. After '97 the wiring changed IIRC.
Old 09-19-2010, 09:05 PM
so i think i found him a PCM for $39
http://cgi.ebay.com/ebaymotors/95-96...Q5fAccessories
it says it may need to be reprogrammed? if its coming from a 96 camaro V6 and going into the same year car it shouldn't need reprogramming right? doesn't the VATS go through the BCM on 96+ cars?
Old 09-19-2010, 09:11 PM
skalor's Avatar
Now that I think about, '96s might only be OBDI. I know for a fact that you can swap in a '97 OBDII PCM though. I wouldn't get anything but a '97 PCM.
Check out Fullthrottlev6.com, there used to be a lot of V6 F-body guys over there.
Old 09-19-2010, 09:20 PM
yeah but that doesn't sound like a plug and play situation. He wants to be able to plug in the PCM and drive off.
Old 09-19-2010, 09:26 PM
skalor's Avatar
http://www.hptuners.com/forum/showthread.php?t=28525
http://www.hptuners.com/forum/showthread.php?t=217
Old 09-21-2010, 08:55 PM
THErobertH's Avatar
ok, OBDII was made mandatory back in 96, however, GM is the exception because they designed it, i have a 95 OLDS achieva that is OBDII, and know that OBDII has been used on some cars as far back as '93. I know for a fact that the 1st zr1 from '94 is in fact OBDII. what sucks is that some can be OBDII an some can be OBDI or hybrids, so you pretty much have to identify it. check the DLC
Quick Reply: is a 96 3.8 Camaro PCM OBD2?
