Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
800+rwhp C5s what diff are you running?
Old 09-19-2010, 12:59 AM
ZeOhhSix's Avatar
Default 800+rwhp C5s what diff are you running?
am now ready for my project and i want to know what differential are you guys running?
Old 09-19-2010, 03:40 AM
MPM IV's Avatar
RPM Transmission STG 3.
Old 09-19-2010, 06:59 AM
ZeOhhSix's Avatar
thanks I will check it , Anyone else have any input
Old 09-19-2010, 07:16 AM
El_Diablo's Avatar
Got mine from ECS.
Old 09-19-2010, 08:25 AM
ZeOhhSix's Avatar
Originally Posted by El_Diablo
Got mine from ECS.
any problem with it ?
Old 09-19-2010, 11:45 AM
El_Diablo's Avatar
Dunno yet. Haven't finished it. Same one they run in their black C5 convertible. Hot-lapping 8's last year.
Old 09-19-2010, 12:44 PM
ZeOhhSix's Avatar
thanks I will see abut that ... any more ?
Old 09-19-2010, 09:13 PM
Red99TA's Avatar
I think if I was making 800RWHP and wanted to actually hook at the track (slicks) then I would invest in a C6Z rear end swap.
Old 09-19-2010, 09:41 PM
ZeOhhSix's Avatar
can you tell me why ?
Old 09-19-2010, 10:01 PM
Red99TA's Avatar
Regardless of what stage C5Z diff you're running there's still guys breaking them at the track - just look over on the vette forum. The C6Z diff is 8 7/8" vs the 7 7/8" on the C5. Also the diff case is beefed up on the C6Z plus the trans ouput shaft is 32 spline vs 27 on the C5Z if I remember correctly. It's no easy swap either. You need the rear cradle, differential and transmission from a C6Z plus some offset diff mounts and then have your exhaust cut and rerouted for a couple inches to make it fit. End product is a bulletproof rear end setup. Buying all the parts used and then selling your C5 diff and M12 trans will help.
Old 09-19-2010, 11:43 PM
ZeOhhSix's Avatar
thanks mate i will see abut that it's sounds good
how abut DTE VI ?
Old 09-20-2010, 10:07 AM
El_Diablo's Avatar
I have a powerglide so mine is on a 3-rib C5 diff from ECS. They were hanging em with 1.28 60's last year.
Old 09-20-2010, 10:17 AM
WS666's Avatar
RPM Stage 3. They make a great product, great service as well.
Old 09-20-2010, 11:33 AM
NoTractionLS1's Avatar
Just get the C6Z rear end and go from there its bigger and will hold up a lot better. If your gonna do it, do it right the fist time and don't cheap out.
Old 09-20-2010, 12:47 PM
ZeOhhSix's Avatar
will see about that thanks my bro
Old 09-20-2010, 12:48 PM
ZeOhhSix's Avatar
many of the guys told me to go with RPM cause it's great as you say up there .
thanks mate
Old 09-20-2010, 12:51 PM
ZeOhhSix's Avatar
the problem is the c6z rear end need to cut the exhaust as the guys in other forum and need to get an M12 gear as the guy in the top says so i will see how much it will cost if a crazy price am going to change the idea and work on my old setup
thanks bro
Old 09-23-2010, 09:54 AM
Moderator
BADZ's Avatar
The C6Z diff is fine but you will want to replace the long side axel and the half shafts. Other then that, the next week link will be the tranny..
Old 09-23-2010, 01:01 PM
ZeOhhSix's Avatar
will heres what am going to do , i emailed T.j@rpmtransmission heres what he says :
You need a ZR1 Tr-6060 with a stage 3 differential.
so thats what am looking for
Old 09-23-2010, 10:17 PM
Red99TA's Avatar
What's the difference in the ZR1 trans and the C6Z 6060 trans?
Quick Reply: 800+rwhp C5s what diff are you running?
