oil pan for 85 regal? LH8 or f-body?
Old 09-19-2010, 11:57 AM
6undrpressr's Avatar
Default oil pan for 85 regal? LH8 or f-body?
Which oil pan should be used for an 85 regal swap? Is it the lh8 pan that hangs down alot lower? Car sits low in the front and dont want to catch anything but also don't want to mod anything for the pan to fit. If either is better then the other does anyone have a part number for the complete kit with everything in it? Thanks guys
Old 09-19-2010, 03:10 PM
86 g-body's Avatar
Retrolsx sales a pan that is the truck and f-body pan in one .Its best of both worlds and it hangs above the crossmember. But its gona set u back almost $400.00.
Old 09-20-2010, 07:44 AM
quickinda6's Avatar
I have did a lot of research and it seems like the cts-v oil pan works it might hang about an inch below the cross member, depending on the swap plates you are using and its like 280$$ total for everything
Vinny
Old 09-20-2010, 09:42 PM
not sure on the motor mounts i have been doing alot of research and might go with the spohn mounts and the stock f-body motor mounts. What about a complete kit part number for the cts-v pans?? I know they have a complete kit including everything for the LH8 pans. Thanks
Old 09-21-2010, 08:43 AM
quickinda6's Avatar
12631828 oil pan cts-v (updated number), 12611129 deflector, 12621299 screen, 12584737 dip stick, 12584738 dip stick tube, total was 270 shipped from www.gmpartsgiant.com
Vinny
Old 09-21-2010, 11:05 PM
toyin's Avatar
I'm doing a 87 GN with a ly6/4L80E and i will be using the CTSV pan. Pick it up on here new for 150. The only thing i don't know about is the oil drain plugs is pointed right at the converter. Don't know if there will be issues with it.
Old 09-22-2010, 09:55 PM
71ANTICARB's Avatar
I am using lh8 pan on my chevelle and other than the price ($130) I am not all that impressed with it. It doesn't fit all that great as they kinda lead you to believe. Don't really know what kind of frame clearance you have to deal with but I will prolly be switching to a f body pan in the future.
Quick Reply: oil pan for 85 regal? LH8 or f-body?
