Tuner wants to drill a hole in my TB
Old 09-19-2010, 01:05 PM
Datzneat's Avatar
Default Tuner wants to drill a hole in my TB
Hi there. My car is your normal ms3/fast h/c/i car. We are having problems with the idle when pushing in the clutch. The rpms will bounce between 300 and 1200 until you come to a complete stop for a few seconds, then it will settle at 800-900. If I don't come to a complete stop it will keep doing this indefinitely. My tuner has tried a few things but now he wants to drill a hole in my fast tb because he thinks this will fix the problem. What's your take on this? I think it's going to cause more problems than it will fix.
Edit: Using HPTuners @ high altitude 6k
Old 09-19-2010, 01:11 PM
vidal77boxing's Avatar
get a new tuner.
Old 09-19-2010, 01:12 PM
jsteele90's Avatar
^^ agreed no need to drill a hole in the tb if you have a knowledgeable tuner
Old 09-19-2010, 01:13 PM
WS6HUMMER's Avatar
I agree
Old 09-19-2010, 01:14 PM
MUSTANGBRKR02's Avatar
Don't do it.
Old 09-19-2010, 01:19 PM
cgslow77's Avatar
was having the same issue on my car and did it and fixed everything... motor wasnt getting enough air i guess... runs great now... we used to do the same thing on old carbed motors with big cams on the primary flaps
Old 09-19-2010, 01:23 PM
Datzneat's Avatar
I understand the part about not getting enough air. But aren't the parameters that you can set to change that in the tune? Also couldn't we get the same results by setting that screw on the tb that changes the rest angle of the blade?
So four new tuner recomendations and one other. lol
Hopefully frost or some of the other knowledgeable tuner guys puts in their two cents.
Old 09-19-2010, 01:27 PM
You can adjust the TB open by the set screw and reset the TPS sensor. There is no need to drill a hole in the TB.
Old 09-19-2010, 01:45 PM
69LT1Bird's Avatar
Adjusting the blade and tweaking the follower and cracker tables will get it done. If your tuner doesn't know those basics, get a new one.
Old 09-19-2010, 03:11 PM
CalEditor's Avatar
Is this a mail order tune?
Old 09-19-2010, 03:14 PM
Datzneat's Avatar
Not a mail order tune. Dyno and street tune.
Old 09-19-2010, 03:15 PM
Datzneat's Avatar
Any advice on adjusting these tables?
Old 09-19-2010, 03:52 PM
01SS99red's Avatar
+ 1 on the ne tuner
Old 09-19-2010, 04:28 PM
69LT1Bird's Avatar
We would need to post the log file and tune for us to really help.
Old 09-19-2010, 04:54 PM
allan808's Avatar
post up ur tune!!
Old 09-19-2010, 05:11 PM
CalEditor's Avatar
I hope you have something better than HPT.
Old 09-19-2010, 05:14 PM
Software is only as good as the person using it. Nothing wrong with HPT. I don't see what this has to do with the OP question.
Old 09-19-2010, 05:32 PM
CalEditor's Avatar
Just so we are on the same page
HPT = 02 SLP & SS & Z28 Auto 12212156 .bin = Total Parameters : 572
JET = 02 SLP & SS & Z28 Auto 12212156 .bin = Total Parameters: 609
EFILive = 02 SLP & SS & Z28 Auto 12212156 .bin = Total Parameters : 680
I own all 3
Old 09-19-2010, 05:34 PM
CalEditor's Avatar
It can be very hard to tune if you don't have all of the parameters.
If you have JET it can be very hard to tune with no Scan-ware
Old 09-19-2010, 05:39 PM
I agree, but if the tuner can't tune out this issue you could add 1000 more fields and he would still want to drill the TB.
This setup is a very common setup that can be tuned with any of the major tuning programs HPT, EFI etc.
Quick Reply: Tuner wants to drill a hole in my TB
