Starting issue, possibly fuel?
For the past month or so, it has taken multiple attempts to start the car. I would have to crank it twice before it would fire. Now it takes 3 or 4 attempts. If the car has only sat for say 3 hours, it'll start up fine, but if it sits over night, or while I'm at work, it takes multiple attempts.
Also, if I start the car, say I drive through my apartment complex, then out to the main road, and I have to make an "evasive maneuver" to get into the flow of traffic, the car will miss fire in the upper rpms.
I haven't been able to find my fuel pressure gauge, so right now it's an assumption that my fuel pump is getting weak. I'm also assuming the fuel pump, or the fuel pump hanger has a check valve or something keeping the fuel from returning from the tank.
I've seen the racetronix kits, and checked out advance auto for fuel pumps. Advance pumps come with the pump and hanger and whatnot, where as the racetronix is just the pump, but a walbro pump.
In my case, would I need the assembly, or just the pump?
