help.. ecm and program for lq9
Old 09-19-2010, 02:12 PM
fyrmanemt's Avatar
Default help.. ecm and program for lq9
can anybody help me out , i have an 07 lq9 im going to put in a project car. 67 firebird conv. have harness but no ecm. i would like to go with a dbc throttle body but do not know which ones will work. anyone done this ? also i need to know what ecm's will work with it and who can do the programming. thanks Tim
Old 09-19-2010, 03:08 PM
CalEditor's Avatar
DBW is the way to go. Much better to set up for engine mods (Cams). You can have better Throttle Response with DBW
Old 09-19-2010, 03:30 PM
fyrmanemt's Avatar
what about problems? are there alot of problems with the dbw stuff?
Old 09-19-2010, 03:46 PM
TrippyJoey's Avatar
TunedbyFrost sells pcms for the LQ9 I believe, plus while you are at it you can get them to do a mailorder tune on it before they send it to you.
Old 09-19-2010, 04:19 PM
fyrmanemt's Avatar
is that his website name as well ? or how do i contact him?
Old 09-19-2010, 04:32 PM
TrippyJoey's Avatar
the website is www.tunedbyfrost.com
Old 09-19-2010, 04:47 PM
allan808's Avatar
get a dyno tune!! mail order tunes arent 100% accurate!! go to ebay and get you a stock pcm then take the car to gforce and get it dyno tuned..youl get every ounce of power out of it and the tune will be safe!!
Old 09-19-2010, 05:05 PM
fyrmanemt's Avatar
thanks for the help with that site. also there is noone around here that does dyno tuning to my knowledge so that will not be possible unless you know of some that i dont.
Old 09-19-2010, 05:15 PM
CalEditor's Avatar
DBW has a lot less issues and the hardware last for a long time. I see trucks with 200K on the OE T-Body.
Old 09-19-2010, 05:40 PM
fyrmanemt's Avatar
ok. i am not apposed to it just not sure about reliability when piecing something together.. that brings up another question though, do i have options on which dbw pedal to use or do i have to find the silverado ss or escalade ?
Old 09-19-2010, 08:04 PM
CalEditor's Avatar
You need the correct year components
Check out SpearTech's website. They have the needed info.
