reset cpu to stock without tuner?
Old 09-19-2010, 04:28 PM
ginoz28's Avatar
Default reset cpu to stock without tuner?
I bought a 2000 camaro to put my 98 motor and trans into and the guy said he had a built motor running nos. I swaped the motor and trans and it starts and idials but when I press the gas it stumbles and bogs down and wont even let it take off.I checked the fuel pressure and its at 60lbs.I was thinking if the tune is messing things up.And what is the cheapest and easyest way to change the tune to stock
Old 09-19-2010, 05:04 PM
badcoup's Avatar
The stealership or some one with a tech2 can do it. It's really simple
Old 09-19-2010, 05:05 PM
badcoup's Avatar
Where are you located?
Old 09-19-2010, 05:47 PM
ginoz28's Avatar
small town 60miles south of san antonio,tx
what is tech2?
Old 09-19-2010, 05:58 PM
1quickirocz's Avatar
what is tech2?
Tech 2 is the scan tool used by gm techs for vehicle diagnostics. If you know anybody thats a gm tech they should have access to it. You would upload the from your car then connect the tech 2 to an online based programming system through GM, download the stock software from there then program it back into your car. doesnt take long.
Quick Reply: reset cpu to stock without tuner?
