TCI deep trans pan
Ok sounds good. I have read that soome guys grind down the inside of the fins so they can use a truck filter to go all the way down incase of any starvation.
Another question...hows the bottom clearance with this pan? Im at stock height but what if I wanna lower the car in the future?
you cant use a truck filter with the tci deep pan unless you grind off the bumps on the bottom. a stock filter will work fine. as far as clearance, havent had any problems yet, even over speedbumps
Not with the TCI pan.
It's best not to reply at all, rather than reply with general comments that may not be fact.
A lot of people use the truck pan, ..., which would lead to the truck filter.
But the OP does not have the truck pan.
The thread title is "TCI deep trans pan".
Have you ever had clearance issues? Can you confirm the trans temps are lower from using this pan?
Iv heard of people having clearance issues but Idk if they are stock height.
Moderator
When I had this pan, I ground down the prongs so I
could run the truck filter.
The lowest point is the drain plug, I collected a lot
of yellow paint on that before I went to the truck
pan.
pan.
Hey Pontiac, who do you think you are talking to?I simply stated that "I was told to use a truck filter with a deeper pan".Last check this board is about information,right or wrong..I didnt tell the guy he had to use a truck filter.
Yea, but you didn't tell the whole truth. You reply was general to have any meaning in reference to this thread topic on the TCI pan shown.
So someone can come along & read your note, buy the truck filter, & the TCI pan with the posts & then end up having to grind off the posts to make it fit. Or take the filter back & get the stock filter.
Did it have the posts in it, to allow the standard stock filter?
Or is it possibly a different TCI pan?
The reason people use the 'truck filter' is obviously because of its longer tube that gets it deeper into the pan, ..., like the deep truck pan
