Which pressure in high volume oil pump?
Old 09-20-2010, 01:48 PM
357i's Avatar
Default Which pressure in high volume oil pump?
I've got the GM high volume oil pump from lingenfelter:
http://www.lingenfelter.com/mm5/merc...egory_Code=C54
Are there any disadvantages to leaving the higer pressure spring in it?
Old 09-20-2010, 01:54 PM
Lt1Porsche's Avatar
None that I have ever noticed. Not for a street vehicle.
Old 09-20-2010, 01:57 PM
1SLwLS1's Avatar
Well, higher pressure typically means more internal frictional losses. How much? Minimal I would assume. I would use the high pressure spring to see higher pressure with larger clearances, such as a rebuilt SB or a block with ~0.002-0.003" clearances. Those engines will typically show much lower pressure, and as long as you're around 50-55# @ red line during WOT, you should be good. Any more than that is just excessive.
Old 09-20-2010, 03:09 PM
Racinjason424's Avatar
I'm running their high-volume ported oil pump... I was at 50-60psi hot idle and it would almost peg the needle at 100psi at WOT. I pulled it back apart and put the standard spring in it.. Now I'm at 50-55psi hot idle and 65-75psi max at WOT.. Not sure if it would have ever been a problem, but it made me uneasy and I was in there for another reason, so I swapped it out..
Old 09-20-2010, 08:36 PM
Arc00TA's Avatar
I have a question along the same lines, I am building a front mount turbo setup, is it worth raising the oil pressure since I would have to feed the turbo also?
Old 09-20-2010, 11:36 PM
printmanjackson's Avatar
maybe this thread will help https://ls1tech.com/forums/generatio...-oil-pump.html
Old 09-20-2010, 11:47 PM
Arc00TA's Avatar
Thats good reading. I guess I should look into the melling 296 pump.
Quick Reply: Which pressure in high volume oil pump?
