head gasket set
Old 09-20-2010, 07:28 PM
cfgioja's Avatar
Default head gasket set
Not sure which set to get. If you haven't kept up with my build. I am running a ls1 block with forged rods and pistons, 243 heads with stock cc, comp cam, dual springs with 1.72 rockers and hi tech pushrods. not looking at installing nitrous or any type of boost at the moment. You never know what the future brings. But for the time being I want it to start and run.
What are the opinions of the masses? I could buy felpro, gm, gm performance, or the most expensive cometic. I am not trying to go skimpy on the last part of the build but money is cutting it close.
Basically I am going to be running high way and mountain roads in higher rpm ranges of the engine. This is in my 944 turbo porsche.
