anyone know where to buy an engine oil cooler?
Old 09-22-2010, 11:46 AM
LT1559's Avatar
Default anyone know where to buy an engine oil cooler?
like the title says....anyone know where to buy one at? i've tried almost every wrecking/junk yard around my area.
Old 09-22-2010, 11:55 AM
CRAZZ28's Avatar
Is there a reason you are wanting to buy one? And IMO just get an aftermarket cooler
Old 09-22-2010, 03:26 PM
shbox's Avatar
If you are going to add a cooler, you don't really want the factory type. Something aftermarket would be much better.
Old 09-22-2010, 04:59 PM
LT1559's Avatar
mine is damaged internally from corrosion, so oil leaked into the coolant passage. what aftermarket brand would you prefer?
Old 09-22-2010, 05:42 PM
RamAir95TA's Avatar
Honestly I'd prefer none. They dropped the KC4 after the 95 model year, so it is not really that beneficial anyway.
Old 09-22-2010, 06:35 PM
fex77k's Avatar
I really hate my stock oil cooler its not a very good design but it still works so I run it, if it ever failed I'd do something like this
Old 09-22-2010, 11:45 PM
am_muscl's Avatar
I have a stock oil cooler that is sitting in my garage. I'll send it to you for $20 shipped. PM me if you want it.
Old 09-23-2010, 12:10 AM
gregrob's Avatar
It's not beneficial for the years that have it, just because they dropped it in later years?
There are situations that these cars get used in (other than drag racing / street duty) where an oil cooler is beneficial.
While I fully agree there are better aftermarket units than the stock, that doesn't mean the stocker is ineffective.
Old 09-23-2010, 12:18 AM
MasterTomos's Avatar
For an aftermarket one, you can use most any tranny cooler. Check out summit or jeg's huge selection of tranny coolers, they are technically "fluid coolers"
Old 09-23-2010, 12:34 AM
speed_demon24's Avatar
That's a great idea if you want to starve the engine of oil considering how little they flow compared to a real oil cooler. If you run an aftermarket cooler make sure the actual cooler is designed for engine oil not transmission fluid.
Old 09-23-2010, 02:28 AM
LT1559's Avatar
Joe, so from 93-95 they were using the "KC4" type engine oil cooler correct? http://shbox.com/1/oil_cooler.jpg
Old 09-23-2010, 10:18 AM
So B&M calls it a "fluid cooler" and an "oil cooler" and it's not capable to cool oil?
http://www.summitracing.com/parts/BMM-70266/
Old 09-23-2010, 10:20 AM
Fastbird93's Avatar
For the OP....I have a factory cooler off my 93 with the lines also......if you want it, just pay for shipping.
Old 09-23-2010, 11:19 AM
LT1559's Avatar
pm sent
Old 09-23-2010, 02:46 PM
LT1559's Avatar
this is my oil cooler that i need
Old 09-23-2010, 03:01 PM
Fastbird93's Avatar
Is there a reason you're sticking with this one? As I mentioned in my PM, this is the worse of the two offered on the LT1.
Pulled from Camaroz28.com
To give a different perspective, and the clarify, there were 2 different oil coolers used on f-bodies throughout the years...
1) used on 93-94 F-bodies, black in color, made out of steel, is a sandwich design, has the cooler lines horizontally mounted to the cooler. Internally it is a high-flow design, suitable for any weight oil. This design is much harder to plug up and has a greater surface area for the oil to make it through the cooler. Manufactured under OEM by Moroso for GM.
2) used on 95-97 F-bodies, bright raw aluminum, made out of cast aluminum with a 'radiator like' finned core, cooler lines mount vertically to the cooler. Internally it is a much more restrictive design and should only be used with 0-5 weight oil. This design is HIGHLY susceptable to clogging and there is no possible way to clean it once it does clog. I believe these may be OEM'd by SLP for GM, but don't quote me on that.
Now out of the 2 designs, IMHO, 1 is a keeper and 2 should be removed the minute you notice it on the car... Cooler #2 is much, much more likely to clog, is ever more likely to cause spun bearings and is a complete throw-away design with less than 1/4 the 'cooling area' the other design offers.
Cooler #1 is more like a oil temp 'stabilizer' than a honest to goodness cooler, as it warms the oil up quicker in winter and cools the oil under higher temps as much as is possible with a 'cooler' of it's size. Thus your oil will stay closer to coolent temps than is possible if you didn't have one. This design can also be cleaned succesfully with larger and more oil passages inside of it and has a much greater radiant surface area, even though it is made completely out of steel, with no aluminum, thus when they redesigned it for '95 they must have felt a smaller aluminum core was just as efficient.
Honestly, it's not a necessity to run the oil cooler. I'd swap to the early style or delete it in it's entirety.
Old 09-23-2010, 09:02 PM
LT1559's Avatar
lol i only wanted to stick to this one because i just wanted to bolt it right on, but since it's so hard to find i'm just going to o'reily's to pick up an oil cooler. which one do you guys think is best between the two:
1) http://www.oreillyauto.com/site/c/de...1365&ppt=C0331
or
2)http://www.oreillyauto.com/site/c/de...1365&ppt=C0331
Old 09-23-2010, 10:04 PM
94Aquaformula's Avatar
Why waist your money on getting a new one? Ditch the junk and be done with it...trust me they do no good.
Old 09-23-2010, 10:24 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I would take it off and leave it off. I'm pretty sure GM never utilized the cooler on the LT1 Corvettes because they came from the factory with Mobil 1 oil. If you insist on having one of the two designs utilized on the LT1, it's always been my understanding that the model used on the 93's & 94's is better. There is also speculation that the primary benefit was bringing the oil up to temp faster, as opposed to actually cooling it off.
Old 09-24-2010, 12:00 AM
LT1559's Avatar
hmm if i ditched it, is there a adapter delete kit or something of that sort that i would have to use?
Quick Reply: anyone know where to buy an engine oil cooler?
