Can you install an oil temp sender in the oil level sender bung?
I am installing a oil temp gauge and was wondering if I can use the hole for the oil level sender to install the oil temp sender? This is on a CTS-V pan btw (although I think the sender is the same between all of the oil pans).
I bought a plug from speedway motors that had the right thread for the oil level hole in the pan. It was also tapped with 1/8th npt, the right thread for my sending unit for my oil temp gauge. Used Autometer gauge and works great. The only problem was the plug was made out of some hard plastic, so I drilled and tapped a very small screw into the side of the oil sending unit (on the surface that you turn with a wrench) for a ground.
I found it at speedway motors http://www.speedwaymotors.com/LS1-Lo...ign=GoogleBase
