LS timing advance goes to 0 at WOT
Old 09-23-2010, 07:36 AM
rskrause's Avatar
Default LS timing advance goes to 0 at WOT
Well, I got a weird one for you guys. I am helping a buddy tune his LS motor. It is an LS3 block but we are using the early LS1 style PCM with a 1X cam position sensor and 24X crank trigger wheel. We are using Tuner Cat OBD II software for tuning and HP Tuners to data log. The car uses the original LS1 knock sensors.
The car starts and runs like a champ everywhere but WOT. As soon as you get to WOT the advance drops right to zero. This does NOT appear to be due to knock retard. We have turned off knock retard everywhere we can find it and HP Tuners does NOT report knock retard. It does show the timing going to zero and that's exactly how the car acts, like it has no timing. Goes flat as hell and stops pulling (we are testing on a chassis dyno with load applied to the rollers).
Any ideas?
Richard
Old 09-23-2010, 08:22 AM
C5kid's Avatar
what are the IAT's? never seen Tuner Cat, but IAT's have a role in timing, as does Max Torque timing.
There are a few tables in the spark table that add or subtract timing.
Old 09-23-2010, 05:00 PM
rskrause's Avatar
There is a table which changes timing according to IAT. We did zero that out.
Ricg
Old 09-24-2010, 06:59 AM
Old Geezer's Avatar
Post the tune??
Post some logs?
Maybe someone will spot the problem............
Old 09-24-2010, 10:03 AM
CalEditor's Avatar
Maybe you want to try Monodax also for some help.
I have seen this before.
Can you post your .cal?
Old 09-24-2010, 10:05 AM
CalEditor's Avatar
Default .bin
Do you know you can save it as a .bin?
Old 09-24-2010, 10:48 AM
rskrause's Avatar
I will post it later or tomorrow.
Rich
Quick Reply: LS timing advance goes to 0 at WOT
