cant get to idle
Old 09-23-2010, 04:03 PM
mike.d's Avatar
Unhappy cant get to idle
car is 02 t.a. with pollutercam ported heads stock maf 42lbinjectors 3600stall lts idle hunts from 400 to 950 idle is set at 950 have hptuners any ides what table to change did t.p.s.reset that stopped cruise controll efect but caused this
Old 09-23-2010, 07:04 PM
69LT1Bird's Avatar
Post the tune and log files. Have you tried adjusting the base running airflow?
Old 09-24-2010, 10:01 PM
TransWS6Am's Avatar
before that, did u adjust for the 42# injectors, a tune and log file would be very helpful also.
Old 09-26-2010, 03:42 PM
mike.d's Avatar
yes adjusted for bigger injectors will post tune thanks guys
Old 09-30-2010, 06:50 PM
mike.d's Avatar
all fixed drilled throttle body blade welded up and drilled to 5.32 biig hole in blade bad thanks guys
Old 09-30-2010, 07:05 PM
TransWS6Am's Avatar
do u mean 5/32? what throttle body are u running?
