Heads/cam with 100k ?
Old 09-23-2010, 06:24 PM
maxspeed05V's Avatar
Default Heads/cam with 100k ?
So im shopping for a f-body.
But sadly the ones in my price range have about 100k.
My future plans for it would be basic bolt ons with a heads/cam combo.
But Id like some opinions, is it to risky to mod a car with milage over 100k?
I dont want something thats going to last just a few weeks.
Would I be better off just waiting untill I find something with better milage ?
or is 100k on a LS1 ok once I change the valve springs, all gaskets and the timing chain and oil pump.
Any input is welcome. Especially if you have higher milage
Old 09-23-2010, 06:27 PM
raidernation3017's Avatar
+1 on that i am getting ready to do a cam swap with a 140k but was wondering the same question
Old 09-23-2010, 07:46 PM
defaultexistence's Avatar
100k on these motors ain't sheeit, a cam swap is essentially a new top end.
do a compression check and if its good your good...100k is just broke in..and finding lower than 75k on these motors is a needle in a hay stack...its been nearly 10 years now since last f-body production...DO Ya Homework
P.s. i have 176000 miles and it'll run ya'll And yes i've ownd an LS1
Old 09-23-2010, 08:33 PM
SSmoken's Avatar
i did cam swap at 130k and heads at 140k. go for it man.
Old 09-23-2010, 09:13 PM
garygnu's Avatar
also consider better rod bolts.
Old 09-24-2010, 07:43 AM
nice, thanks for the input
I dont want to go as deep as rods and rod bolts and etc, dont want to get into the bottom end.
Old 09-24-2010, 08:23 AM
RedRocketZ28's Avatar
I know a couple of different cars around here who did heads/cam swaps with over 100k. One spun a bearing with a little over 100k on it (4k on the swap) and the other one has close to 150k on it and it runs strong. Anything can happen. Hell, I did a cam swap on my car when it had 16k on it and I now have 42k on it. No problems yet, but I get paranoid everytime I hear the motor make a different noise, ha.
If the car was taken care of then you shouldn't have any problems. Good luck with the search.
Old 09-24-2010, 08:54 AM
los p's Avatar
i did a h/c at 130k and know have 144 and still running strong!
Old 09-24-2010, 09:02 AM
Lt1Porsche's Avatar
No problems man. Give the vehicle a general check over and if all is well, go for it. I just did a cam swap at 103K. No fear.
Old 09-24-2010, 09:17 AM
JustAnotherLS2's Avatar
I would'nt say just broken in, but 100k really isn't as bad as you think. And yes like stated earlier, you're essentially getting a new top end with a cam swap, assuming you're doing it the right way.FWIW, My car will be right around 100k as well, when I'll have the funds. I say, go for it.
Old 09-24-2010, 09:18 AM
00pooterSS's Avatar
It will be fine, and just an FYI someone posted above about spun bearings, they are not from higher horse power from a H/C swap, they are from oiling issues or too high of RPM's which is what rod bolts are needed for (higher RPM's that stretch the bolt allowing the bearing to spin). So don't worry about rod bolts if you are not spinning it up to rediculous RPM's. For what its worth I have 182k on mine and it has been spun to 6700 for the last 2 years/25 or so thousand miles. The bottom end will take the power increase no problem. Its RPM's and improper put together setups that are the killer, LS1 bottom ends can take the power increase all day.
There are plenty of people on the board that have done cams etc.. above 200k, just maintain the car and dont go trying to rev it to 7k and you will be fine.
One last thing, I would actually be skeptical of any LS1 F body out there with less than 100k, they are on average 10 years old, I know there are a few but... very few.
Old 09-24-2010, 10:16 AM
I know oil can be a issue, I was thinking of going with a ported ls6 pump with a ls2 timing chain. Unless you guys think aftermarket would be better. But I've always had best luck with oem.
What about lifters ? Ls7 or should stock be ok.
Old 09-24-2010, 10:52 AM
Bizzles's Avatar
Have seen a few 200-250k ls1 vettes with factory stock bottom ends. My car is @ 111k, took the heads of and the cylinder walls STILL had the cross hatching in them. going H/C @ 100k mi has the same chance of blowing up as doing H/C @ 50k mi, it's more dependant on the maintenance over the life of the motor and the correct install than milage.
Go for it!
Old 09-24-2010, 11:07 AM
Atomic02's Avatar
as long as the proper maintenance has been done and you get all supporting mods you'll be fine. my buddy had a 98 ss with 150k cam only runnin low 12's all day
Old 09-24-2010, 12:53 PM
SSmoken's Avatar
i agree. as long as the motor has been taken care of, everything should be fine.
Old 09-24-2010, 01:33 PM
Jon@Texas-Speed's Avatar
We get guys with 100+k miles on cars starting to mod them all the time. I couldn't tell you how many of those guys are running MS4 cams too! As long as you put good components in with the heads/cam and take care of it, you shouldn't see an issue. It's a good idea to do a compression and leak down test as well. You don't want to put heads/cam on the car just to be disappointed that the rings are worn out and not sealing. That will also effect your gains from your setup. Let us know if you we can help!
Jon
Old 09-24-2010, 02:12 PM
mike171562's Avatar
Ive been pondering this myself at 120K
Old 09-24-2010, 06:31 PM
BayArea ws6's Avatar
do it do it do it do it........oh yeah and do it right!
Old 09-24-2010, 06:44 PM
airforcemanss's Avatar
i actually drove mine way too much the past yr because of damn beaters shittin on me...just hit 70k a few days ago. g5x3 afr 205 59cc combo in the works. do it!
