hooker super comp lts
ok i just bought some hooker super comps for realy cheap never been installed...and one of the pipes comes apart from the header to go around the steering thing..i was wondering if any one has had a problem with it leaking? and if so wat did u do to fix it? thanks
I put some high-temp RTV on the outside of the smaller piper when I pushed them together.
Still leaks a tiny bit, but I honestly can't think of any other solutions. I guess I was hoping someone would have come up with a better one by now lol.
ok this is what i was planning on doing just wanted to make sure that some didnt haver a better idea..lol i was thinking of like a small clamp like some do on the exhaust bit it would hvae to be a very small one..
pull it apart and clean the pipes with a wire brush where they slide into each other then coat the male side with rtv and pop it in and make sure you give it overnight to dry and harden up before you fire it
this should take care of it unless the pipes are damaged
nope no need for the clamp all that will do is distort the pipe opening.....copper rtv will work justttttt ffinnneeee.....again like i said above just give it like 12 hours of drying time before you fire it up
hmm thats a long time..lol might *** that part up..lol i like hearing it..guess ill have to fix the rest of my exhaust before firing it then..lol thanks
