Is it possible to have trans fluid to cold?
Old 09-24-2010, 11:02 AM
senicalj4579's Avatar
Default Is it possible to have trans fluid to cold?
My setup will be this...
2 b&m coolers mounted dope style,a tci deep pan that adds 2 qts,and I will bypass that radiator.
I dont drive the car in the winter a whole lot (im in ct) but im wondering if I do...is there any chance that fluid can be to cold? Even if the car is cold started up I dont see why the tc wouldnt heat up the fluid enough. What do you think?
Old 09-24-2010, 11:27 AM
01ssreda4's Avatar
I believe trans fluid has an anti gel agent so it doesnt freeze at normal freezing temps. And the B+Ms should have a fluid bypass built in for the event of obstruction (from say a clog or over-gelled trans fluid if there is such a thing) I would run this set-up during the summer/spring/fall and hook in the radiator cooler/warmer during the winter. Wouldn't take but 1 hour or so each time winter comes/leaves. Also, T the two coolers, don't run them inline with each other. This could cause excessive restriction in fluid flow. Plate coolers don't flow as well as tube and fin. I bought some t barbs made for 3/8 hose from summit I think in the event I decide to add another cooler. I chose the one big cooler route as opposed to 2 smaller coolers so I never used them. They were only a couple bucks a piece. Actually I might have bought them from Home Depot. They have a nice selection of brass barb fittings.
Old 09-24-2010, 11:45 AM
Thats also another debate im having.. running in series vs parallel. I have one well known person on here telling me series and the other well known person telling me parallel.
Whats size are the stock trans lines? Im trying to figure out what I need so I can go get the stuff. If I run in parallel obviously im gonna need 2 T fittings,10 hose clamps,and what is it 3/8 hose? Am I thinking right?
Old 09-24-2010, 02:53 PM
01ssreda4's Avatar
If you are running 2x B+M 70264s then yes 3/8 will do.
Old 09-24-2010, 03:04 PM
01ssreda4's Avatar
From the transmission section stickies, in particular someone who builds performance transmissions for a living. I am telling it to you bc I have had a thrust bearing failure on an engine. Pay particular attention to number 3 and 4:
Originally Posted by performabuilt
Tips, Hints, For Transmission Cooler installations
________________________________________
Many of you add aftermarket coolers to your cars and this is allways a good idea. Here are some hints.
1-Allways mount the cooler in a place that has good air flow and if mounting in front of the radiator always make sure the fin's in the cooler are parallel with the fin's in the radiator to avoid restricting air flow to the radiator. If you must place the cooler in and area with little air flow a FAN is a must.
2-When Installing coolers make sure lines are clear of anything that can rub them and always use line that’s approved for transmission/hydraulic fluid. Fuel line will not work and will break down in transmission fluid.
3-By passing the radiator is the way I prefer a cooler be set up. Generally the transmission will run cooler this way and additionally this may take some of the load off the radiators job of cooling the engine.
4-When hooking up multiple coolers several things should be noted. The cooler itself is a restriction of flow and this restriction while not a problem for the cooling or lube to the trans can cause excessive pressure inside the converter. This can force the converter against the flex plate more so than normal and cause wear to the engine thrust bearing. A stopped up or severely restricted cooler or cooler lines can do the same. So when installing more than one cooler its advised to put them in parallel with each other, This means one line from the trans is split with a Y and one line run to each cooler then out of each and into a Y back to a single line running to the trans. This will assure adequate cooling while reducing the wear to the engine thrust bearing. Always use line that’s at least as large as the inlets in the cooler, Avoid extreme twist or turns in them particularly with rubber lines.
5-Type and brands of coolers; I really have no preference here as far as brand. From my experience and expensive brand name or a generic unit appear to do the same job. I have found the stacked plate (Flat tube) Types when measured inlet to outlet temp drop tend to be more efficient in the same dimensional sizes with a greater temperature drop. I did a test once with two coolers in parallel one round tube and one flat with a laser thermometer to determine this.
6-This is not specifically about a cooler but about cooling. Always be sure that the metal lines coming from the transmission under car do not contact the headers or exhaust. I once had a car where the transmission temps would sky rocket when the car was being run hard and couldn’t understand why. I after some looking around found that the cooler lines in and out were pinned against the headers. This would super heat the fluid when the headers got hot. Moved them away and the problem was solved, So always keep trans cooler lines factory or otherwise as far away from the exhaust as possible.
7-Trans temps- This question gets ask a lot. What’s TOO HOT? Well ideally you want you average temp to stay under 190 degrees however I would not get to concerned till the temps get at and or over 230 degrees. Heat can damage a trans but with the exception of extreme heat 250 or higher this damage is a long term killer by breaking down fluid and causing rubber seals to harden and break.
8-Never use your cooler lines to remove fluid from your transmission by starting the engine or in and attempt to flush by catching fluid in a pan while adding fluid to the dipstick. When this is done no lube is being sent to the planets and bushings and they can go dry and melt down very quickly destroying or significantly shortening the life of your transmission.
9-It is advisable to fully and properly flush a cooler especially when a converter failure is involved. Where a transmission internal failure is unlikely to put debris in the cooler since all fluid coming from transmission must travel through the trans filter. The fluid coming from the Pump or converter does not and any debris from these will certainly end up in the cooler. Its always a good idea to power flush a cooler or replace after a failure but is particularly important in the case of this type failure. Anything that’s in your cooler or lines will end up in your Valve Body, Bushings and Planets. A cooler cannot be properly cleaned simply by blowing air through it. A can of cooler flush which most transmission shops and or transmission parts suppliers should have followed by a blow out with air is the correct way to do it.
10-When installing rubber cooler lines to metal lines it’s a good idea to put a small flair at the end of the metal line. Not too big because you will tear the line on the inside during install. Then place a clamp just ahead of the flair. Also roughening up the outer surface of the metal line with very coarse sand paper in area where clamp will ride will help assure a good seal and reduce the possibility of blow off. Never over tighten clamps to the point of the rubber oozing through or being cut this will cause a failure too.
11-Temp sending units- The best place for these is in the pan since that will give the best average temperature which is what’s important, using the pressure port is ok however you will show temps 10 to 20 degrees higher average than you would in the pan. I do not suggest placing temp senders in either the inlet or outlet from the cooler as they will increase cooler restriction and increase the odds of a leak.
Old 09-24-2010, 03:20 PM
Iv been through that sticky quite a few times but idk why I got different info from someone else about the series vs parallel.
Another note...iv decided to install the coolers a little different. Ill probly catch some heat but I dont see a problem with it. They will be installed just a little lower than most people do dope style. I didnt wanna hack the plastic under the car. They hang just as low as my ssra and iv never had any problems with scraping the ssra. Ill post up some pics for people (in parallel,and dope style without hacking any plastic.
Old 09-24-2010, 08:44 PM
joecar's Avatar
Why do you need two B&M 70264 coolers... isn't one sufficient (I didn't think CT got that hot)...?
Old 09-24-2010, 09:01 PM
Wll I couldnt install the biggest one because I have a ssra taking up the space by the radiator. So I figured I would use 2 smaller ones just to make sure.
Old 09-24-2010, 09:44 PM
01ssreda4's Avatar
your best bet is to have a tranny temp gauge so you can see how effective your cooling is working.
Old 09-25-2010, 07:26 AM
I agree for sure. I have a aeroforce interceptor coming on mon. Cant wait to try it out.
