Parts Classifieds - Crane Cams Chrome moly pushrods 7.250" and Roller Rockers
72Elkytpi
09-24-2010, 05:09 PM
$115
Crane Cams 95625-16 - Crane Pro-Series Pushrods
Pushrods, Pro-Series, Chromemoly, Heat-Treated, 5/16 in. Diameter, 7.250 in. Length, Universal, Set of 16
http://www.summitracing.com/parts/CRN-95625-16/?rtype=10
$199
Crane Cams 144759A-16 Rocker Arms, Gold Race,
-3/8 in. Stud Mount,
-Full Roller,
-1.8 Ratio
-just the rockers
-used on dyno.
-few wear marks but work great.
cost $459.9 new
http://www.summitracing.com/parts/CRN-144759A-16/
72Elkytpi
10-02-2010, 06:26 AM
BuMp...
72Elkytpi
10-03-2010, 03:08 PM
one point people are asking about, the longer 1.8 rocker requires a shorter 7.250" pushrod. Also the rockers need a 3/8 stud instead of the stock bolt that holds the factory 1.7 rockers.
72Elkytpi
10-10-2010, 11:53 AM
bump...
taman86
10-15-2010, 02:23 AM
using the shorter length pushrod keeps the valve lift the same then. why are these required?
taman86
10-15-2010, 02:57 AM
nm, figured it out, thanx
