160 or 180 degree thermostat?
Old 09-24-2010, 10:02 PM
l 95 Trans Am l's Avatar
Default 160 or 180 degree thermostat?
Im sending my PCM out monday to get tuned. Should I get it tuned for 160 or 180 degree thermostat? The car will be driven in the winter (when its not snowing of course). I was thinking 180?
Old 09-24-2010, 10:12 PM
RamAir95TA's Avatar
160. Stock is 180.
Old 09-24-2010, 10:13 PM
shbox's Avatar
If you live where it snows much, you probably want the 180 in during the winter.
Old 09-24-2010, 10:15 PM
pboxfun's Avatar
160 thermostat
Originally Posted by RamAir95TA
160. Stock is 180.
Wow. I was told that the stock was a 210.
Old 09-24-2010, 11:23 PM
SexyTransAm's Avatar
+1 for 160
Old 09-25-2010, 08:18 AM
shbox's Avatar
Obviously by someone who did not know much.
Old 09-25-2010, 09:40 AM
Tbird232ci's Avatar
I run a 160 year round, and here in maryland, we get some cold winters. I've never had an issue with heat. Don't fear the 160.
Old 09-25-2010, 10:11 AM
That's MISTER MODERATOR
Paul Bell's Avatar
160 ftw
Old 09-25-2010, 04:39 PM
96capricemgr's Avatar
I have run a 160 in subzero weather and long as the heater core is not plugged you get plenty of heat. That said I do not believe a 160stat is a critical mod atall.
Old 09-25-2010, 04:46 PM
Paul Bell's Avatar
96 is correct. It's not a critical mod. HOWEVER, my LT1 and LS1 car both ran better with the 160 mod. Don't know if it added HP. The heater core on my LT car was blocked solid-pressure from a garden hose cleared it out, you'll get soaked though...
Quick Reply: 160 or 180 degree thermostat?
